Big Single TURBO build ...LOADING
Tansman
Re: Big Single TURBO build ...LOADING
Post by Tansman » Wed Feb 06, 2019 6:15 am
I finally started on my hotside piping. Here's the first few pieces. I cut the stock flange off of the catalytic converter. In the future I would like to buy V-Bands for it.
2012 Chevy Caprice- VSR80 turbo, BTR stage 2, 3.45s, camaro wheels, meth injection (racecar/ weekend car)
2007 Honda Civic SI- Sedan- intake, exhaust, Skunk2 short shifter, shift bushings (wife's daily)
2005 Chevy tahoe- Cold air intake, everything else stock! (The family car)
2000 Honda civic Hatchback- lowered, rota slip wheels. (My daily)
Tansman
Post by Tansman » Wed Feb 06, 2019 6:17 am
Here's the next couple pieces, and the flex pipe.
Tansman
Post by Tansman » Wed Feb 06, 2019 6:19 am
I'm going to have the driver side manifold flipped like this, and I plan on 90' ing right into the flange.
I'm gonna have to relocate the coil packs and figure something out for the plug wires, if anyone has any ideas up open to listen!
Tansman
Post by Tansman » Wed Feb 06, 2019 6:22 am
The turbo flange will be sitting right around here.
Tansman
Post by Tansman » Wed Feb 06, 2019 6:26 am
This is the welder I have been using. I'm not a welder and this has probably been the most I've ever welded. It's not perfect but I think it'll work! If you have any constructive criticism please share, because I really don't know what I'm doing here. As far as welding, exhaust, and just general building a turbo kit. I
cabledawg
Wastegage?
Post by cabledawg » Wed Feb 06, 2019 2:51 pm
Curious where you are going to put your wastegate/gates?
PS- Nice boat.
Post by CrashTestDummy » Wed Feb 06, 2019 4:05 pm
Not bad welds for a non-welder. ;)
I think I would have opted for oval pipe for the crossover. I can imagine that pipe getting beat up in use. Not cheap, but you could gain some clearance while also maybe gaining some pipe size.
2010 Tahoe PPV (her car)
lastcall190
Post by lastcall190 » Wed Feb 06, 2019 10:28 pm
+1 with no welding experience, those don't look bad (my first weld looked like a bunch of charred nerds slapped on the joint)
My only concern is as the crossover passes under the flexplate area, might that be a lot of radiant heat headed up towards the torque converter area?
I have no experience with turbo'd V8s so odds are I am very much misguided in my concerns.
Good luck on rest of build.
Post by xcidmigs » Wed Feb 06, 2019 10:59 pm
I agree about the heat, I would consider wrapping that crossover section in heat wrap tape or getting that pipe coated, is that aluminized pipe you are using? If yes I would go with the coating as the wrap will just retain moisture and make it rust out, ask me how I know.... I have eastwood same exact welder its great but the wire they ship it with will rust in the welds....
Tansman
Post by Tansman » Thu Feb 07, 2019 3:43 am
I dont know a whole lot about how the heat will affect the torque converter. But I do know that just about everybody runs their crossover in that spot, that's why I did it. I am a little uncomfortable with how close it is to the cooler lines. I will be wrapping it but I think I would like to get a bigger aftermarket trans cooler in the future.
If I have problems I might switch it up. But I actually opted for a smaller pipe size to help spool a little quicker.
PS- Nice boat.
I'm gonna run 2 wastegates, because it's a split system. I'm going to put one right on the bend right after the driver's side manifold, and the other down bottom somewhere probably. I'm kinda doing this as I go and don't really have a plan for everything. I'm not skilled enough to plan everything out!
I plan on painting it with some high temp and then wrapping it. It is aluminized pipe. Hopefully by the time it rusts through I can afford to go stainless I guess! I'm using lincoln brand wire from home depot.
Also thank you everyone for the feedback!
