Big Single TURBO build ...LOADING
Tansman
Re: Big Single TURBO build ...LOADING
Post by Tansman » Thu Feb 14, 2019 7:38 am
Here's my current To Do list
-Relocate power steering reservoir
-mount wastegates
-shave and wrap headers/crossover
-mount intercooler
-plumb intercooler piping
-figure out upper radiator hose
-remove coolant tank, and find aftermarket replacement
-figure out MAF
-make downpipe (out the fender)
-install wideband and gauge
-install boost gauge/ boost controller
-install meth kit
-and probably a butt ton more
Also I don't know why my pictures keep posting sideways or upside down.
2012 Chevy Caprice- VSR80 turbo, BTR stage 2, 3.45s, camaro wheels, meth injection (racecar/ weekend car)
2007 Honda Civic SI- Sedan- intake, exhaust, Skunk2 short shifter, shift bushings (wife's daily)
2005 Chevy tahoe- Cold air intake, everything else stock! (The family car)
2000 Honda civic Hatchback- lowered, rota slip wheels. (My daily)
Tansman
Post by Tansman » Sun Mar 03, 2019 5:22 pm
Small update, I picked up this center console from a local part-out for $40! Came with whole console and shifter. I want sure if I needed the brake cable, but he said I can come back and get it if needed.
Tansman
Post by Tansman » Wed Mar 20, 2019 4:34 am
Small update, I haven't been working on it much. Been busy with other stuff! So I picked up this center console with the shifter and everything for $40!!
And I also made up some brackets for a couple of the coils. So the wires aren't resting on the headers. And I also made some wires as well. I still need to go buy a couple nuts and bolts to tighten everything down .
Also! I picked up this workbench for $60! Definitely alot nicer having an area to work. I have a chromebit PC stick hooked up to the tv so I can Google or YouTube whatever I need.
Post by Pursuit » Wed Mar 20, 2019 5:12 am
Nice work-around for the coils! And a Chromebit stick for the quick how-to videos!!
Tansman
Post by Tansman » Fri Apr 12, 2019 2:35 am
I moved the power steering reservoir to the cabin air box today. Turned out pretty clean. I just zip tied the hoses to the top of the engine. I got the idea from another guy on here.
Tansman
Post by Tansman » Sat Apr 13, 2019 7:58 pm
I'm working on mounting the intercooler today. I'm lucky enough to have a tig welding neighbor!
Tansman
Post by Tansman » Sun Apr 14, 2019 4:32 am
Few more pics of it mounted
lastcall190
Post by lastcall190 » Mon Apr 15, 2019 9:48 am
The build is nice but dammit if the console for 40 bucks is even more impressive :lol:
It seems you're fairly industrious, so a few welds later and you could resuse your stock 9C1 e-brake cable. I think a few here have done it (I believe there are pics posted by user "PPV")
Nice work bench as well!
Tansman
Post by Tansman » Tue Apr 30, 2019 2:01 pm
I worked on the intercooler piping this weekend. I got it routed up to the turbo, but I still need the flange welded to a piece for the vband. I also routed it under and to below the throttle body.
I plan to 90 down from the throttle body and run this LS7 maf housing.
Screenshot_20190430-075629_Amazon Shopping.jpg (241.51 KiB) Viewed 3900 times
Tansman
Post by Tansman » Tue Apr 30, 2019 5:47 pm
I also got both flanges for the Vband welded on. I didn't have much room to play with for the one coming off the driver side. So placement isn't perfect as far as flow, but I will have twin 50mm waste gates so I don't think it will be an issue. I also wrapped the driver side. I'm waiting on more wrap now to finish the crossover. Also, I sprayed them with VHT ceramic coat before I wrapped them too. To try to help fight off rust.
