Big Single TURBO build ...LOADING
Tansman
Re: Big Single TURBO build ...LOADING
Post by Tansman » Wed May 15, 2019 2:15 am
CrashTestDummy wrote:
Mon May 13, 2019 5:08 pm
I'm surprised the rear tires don't light up every time you open the trunk with all those stickers! :lol:
So am I!
I had to pull it out of the garage so I figured I'd get a picture. Seats are out to run the meth injection wires. If you're on the Facebook page I posted an idle video!
2012 Chevy Caprice- VSR80 turbo, BTR stage 2, 3.45s, camaro wheels, meth injection (racecar/ weekend car)
2007 Honda Civic SI- Sedan- intake, exhaust, Skunk2 short shifter, shift bushings (wife's daily)
2005 Chevy tahoe- Cold air intake, everything else stock! (The family car)
2000 Honda civic Hatchback- lowered, rota slip wheels. (My daily)
sar94
Post by sar94 » Thu May 16, 2019 2:44 am
Sounded great on facebook..keep at it you are almost there.
Tansman
Post by Tansman » Sat May 18, 2019 9:05 pm
Finally got the meth line ran to the front, mounted the pump in the spare tire well.
Tansman
Post by Tansman » Sat May 18, 2019 9:28 pm
Trunk looks clean again!
Tansman
Post by Tansman » Wed May 22, 2019 2:51 am
I had the down pipe off to weld my o2 on, so I painted it gloss black with some hightemp paint. It looks a little more stealth now .
I plan to wrap this too up to right before it comes out of the fender.
Tansman
Post by Tansman » Tue May 28, 2019 1:18 pm
I put the meth nozzle in the silicone 90 before the throttle body. I used this piece from Amazon and flap disked it down until it was as thin as I could get it so the nozzle would be exposed and hopefully be able to have a good straight spray into the TB.
Screenshot_20190528-070939_Amazon Shopping.jpg (524.44 KiB) Viewed 8864 times
Tansman
Post by Tansman » Tue May 28, 2019 1:21 pm
Blow off valve flange is welded onto the 4in spectre pipe. I put it about 6in or so before the maf. I read that's about the best placement for it.
Tansman
Post by Tansman » Tue May 28, 2019 1:23 pm
The turbo outlet has a leg coming off it now, this was the last piece I needed to fully connect the coldside!
Tansman
Post by Tansman » Tue May 28, 2019 1:27 pm
I'm doing an IAT breakout so the IAT will be after the methanol nozzle. Its going into the short tube right in front of the TB. I wanted it in the intake but I don't know where people usually put these. So this should work!
Post by CrashTestDummy » Thu May 30, 2019 3:01 pm
Nice work. I have GOT to learn how to TIG!
2010 Tahoe PPV (her car)
