2014 Caprice not conventional build
My new to me 2014 Caprice V8
Up to about 2 months ago I had no idea on what a 2011-2017 Caprice was, To me it was another pos fwd car that I wanted no part of.
Then a friend of mine lists one up for sale and I actually looked at it and saw that the car was RWD and that it had an LS motor in it.
fast forward 2 weeks and I bought the car knowing absolutely NOTHING about them besides what he told me, NEEDS dod deleted and some other stuff, guess what I didn't know what dod was or that it was even a problem but I proceeded anyways.
About a week after getting the car the Cam, lifters, timing set, oil pump, Valve springs and seals and pushrods have been swapped.
I just purchased HP tuners (I wanted to never deal with this but here I am I prefer standalone systems)
Car needs
Paint work
driver seat swapped - already have a spare
Fender vents = just ordered hopefully on their way
Spare tire and jack set
windshield washer line fixed
Rubber flooring replaced with anything but it.
Wheels replaced - I hate them steel wheels = I have a lead on some 18 inch Camaro wheels-hopefully it works out.
Trunk and hood have a few holes that need fixing.
A-Pillar spot light needs to be gone
Console needs some work
Drivers door panel has some damage
Need to figure out the rear door lock-unlock mechanism.
Need to figure out the Bluetooth on the radio.
I am probably going to do somethings different - I have NO care about Holden, SS, G8 or want anything to do with the cop car themes.
plans for the car
Most likely buying two carpets for a maybe 80s A-body and cutting/trimming and making them fit.
No plan for the radio yet.
Car needs
Paint work
plans for the car
- Caprice vents 2.jpg (2.85 MiB) Viewed 9681 times
- Caprice vents 3.jpg (2.98 MiB) Viewed 9681 times
- 20201111_135133.jpg (8 MiB) Viewed 9681 times
- 20201111_113356.jpg (2 MiB) Viewed 9681 times
- 20201111_195133.jpg (4 MiB) Viewed 9681 times
- 20201111_195128.jpg (8 MiB) Viewed 9681 times
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
Re: 2014 Caprice not conventional build
Got a GREAT deal on a set of wheels with good tires
and uploaded new tune
https://youtu.be/yy_-JnDE2-I
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
Because I didn't like what is available I made my own.
https://www.youtube.com/watch?v=FHhWQQs ... ED&index=2
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
Car needs
Paint work
driver seat swapped - already have a spare -- Done
Fender vents = just ordered hopefully on their way stock = Done
Spare tire and jack set Done
windshield washer line fixed Done
Wheels replaced - I hate them steel wheels = I have a lead on some 18 inch Camaro wheels-hopefully it works out. Done
Console needs some work Almost Done
Need to figure out the rear door lock-unlock mechanism. Done
Need to figure out the Bluetooth on the radio. Done
Still NEED to fix
The horn
Lights still flashing
Drivers door panel has some damage - Not sure what I going to do
Rubber flooring replaced with anything but it. - Probably not happening
Paint work
Still NEED to fix
The horn
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
- Brokecello
So all that light was just from upgrading the stock bulb to LED? That is pretty slick!
-- 2014 Caprice 9C1 - Retired Washington County (OR) Sheriff Dept Unit
-- 2014 Caprice 9C1 - Retired NC Dept of Corrections Prisoner Transport
YES/NOBrokecello wrote: ↑Wed Jan 13, 2021 1:38 pm So all that light was just from upgrading the stock bulb to LED? That is pretty slick!
LED 6 inch strip
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
Plaiti dip the doors, upper side panels and polished trim
and it came out better than i thought it would.
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
Looking good!
