1/4 mile with Mod List
This section is for all your track and racing topics. Sanctioned events, test n' tune, competitive track & racing at public facilities, off-street drag events, it all goes in here.
BarryM
Post by BarryM » Mon Oct 26, 2020 3:42 pm
First Time at the track with my Caprice PPV:
1.73 60'
7.85 @ 88.1 1/8
12.32 @ 110.7 1/4
155K mile short block and transmission - PPV Steel Rims
Camshaft TSP Stage 1 LS3 N/A Camshaft 225/236 .629"/615" 114 LSA, 109 ICL
Texas Speed and Performance CNC Porting and CNC Valve Job of # 823 factory heads
TSP DOD Delete
Camaro 6L80 deep transmission pan and wide mouth filter
Torque Converter - Precision Industries 3600
3.27 Limited Slip Differential
Kooks Headers, No catalytic converters, 2.5” SOLO exhaust
Roto Fab Cold Air Intake
Hoosier DOT Drag Radial Tires 245/40-18
PB1117SS - PowerBond Race Performance Harmonic Balancer
Oct 23.jpg (83.17 KiB) Viewed 904 times
First time track.jpg (370.07 KiB) Viewed 904 times
BarryM
Re: 1/4 mile with Mod List
Post by BarryM » Mon Nov 09, 2020 3:47 pm
Update - Improvement
Charles Barber tweaked, thanks sir !
Increased tire air pressure to 26
1.68 60'
7.73 @ 88.9 1/8
12.13 @ 112.7 1/4
Second time track.jpg (204.95 KiB) Viewed 817 times
BarryM
Post by BarryM » Mon Nov 09, 2020 3:57 pm
kevink
Post by kevink » Mon Nov 09, 2020 5:15 pm
Nice work. You can probably knock off a tenth or two with skinnies.
Post by CrashTestDummy » Wed Nov 11, 2020 4:22 pm
You can probably knock at least half a tenth going with a wheel that's NOT the Caprice wheel. Those things are heavy, and going with even a different steel wheel will cut some rotating mass. Aluminum would be even better.
2010 Tahoe PPV (her car)
Turbopowered68
Post by Turbopowered68 » Mon Nov 16, 2020 3:24 pm
BADASS
2014 Caprice V8
Elgin E-1840 P, LS9 Head gasket, LS7 Lifters, trunion upgrade
Single roller timing set, Melling oil pump
1986 GN Roller cam, HR Rockers, Bigger turbo, XFI, E85, Front mount IC, Built trans, 3.42 gears.
1968 Chevelle LQ4, 4L80, 12 bolt w/3.42 gears
