3.27 Camaro diff
Post your Caprice PPV parts & components for sale here.
undrcvrppv
3.27 Camaro diff
Post by undrcvrppv »
Upgrading to a zl1 diff so I'm selling my 3.27 that I recently purchased from Camaro 5 it has 28000 miles on it. I never installed it just looking to get back what I have into it 600 firm shipped
undrcvrppv
Re: 3.27 Camaro diff
Any takers? open to offers
what all did you do to get the ZL1 diff to work ?
undrcvrppv
I don't have everything yet. Looks like drive shaft aftermarket Axles and bushing should be all
oh , thats not good then , i was hoping you had done the work already , and sounds like you havent researched it far enough yet
you are better off getting the complete ZL1 cradle and doing a cradle swap , that saves buying axles , you will need to reuse the caprice sway bar , as the camaro bars are straight between the 2 frame mounts , and will not clear the spare tire tub
yes youll need a custom driveshaft , if you try and reuse the stock cradle , you will need to cut it up to clear the diff , untill you see the sheer size of the ZL1 , i know that sounds odd on the work to get it to fit
im actually getting the whole the cradle
undrcvrppv
I saw someone put the diff in a caprice cradle there was no mention of having to cut it all up. I need upgraded axles for the power I'm making as well as the custom driveshaft
