Post your Caprice PPV parts & components for sale here.
GammaFlat
Post
by GammaFlat » Tue Nov 24, 2020 10:31 pm
Brand new unused Holden Motor Mount as sold here for 295 per pair:
https://holdenpartsusa.com/products/tec ... -mount-set
I was going to change both and they come in pairs - I changed my mind. I did driver's side only (side that gets pulled on). Some say change both of them but I'm not convinced that the passenger side is at high risk (it gets pushed instead of pulled). Mine is fine so far with one done. Both sides use identical part. The Holden part looks absolutely bullet-proof. See the link above or picture below. $150 and I'll pay shipping in lower 48.
This is easier to install than the factory one is to remove. The factory one (rubber and brown goo) has studs on top and bottom. This causes you to need to lift the engine to kingdom come in order to get it out. Since the new one has a stud and a bolt, it is much easier to get in place than a GM factory replacement. As a matter of fact, I'd recommend cutting the old one out - raise up the motor and cut the stud with a dremmel, torch or cut-off wheel. I did not feel real comfortable raising the engine as much as I did
- Motor Mount.jpg (6.93 MiB) Viewed 499 times
2013 9C3, Solo axle back, deeper trans pan, 3.27 diff
Turbopowered68
Post
by Turbopowered68 » Wed Dec 16, 2020 12:33 am
i'll take it
you have a PM
2014 Caprice V8
Elgin E-1840 P, LS9 Head gasket, LS7 Lifters, trunion upgrade
Single roller timing set, Melling oil pump
1986 GN Roller cam, HR Rockers, Bigger turbo, XFI, E85, Front mount IC, Built trans, 3.42 gears.
1968 Chevelle LQ4, 4L80, 12 bolt w/3.42 gears
GammaFlat
Post
by GammaFlat » Tue Dec 29, 2020 8:18 pm
Now gone.
