Current Informational and Technical TSB listing - 12/3/2013
Information on recalls (EPA, NHTSA, etc..) for the 2011 & up Caprice along with details on General Motors Technical Service Bulletins (TSB's). This forum is read only.
Locked
Post by elc32955 » Fri Dec 06, 2013 12:21 pm
Folks,
NavyLifer took the time to obtain for us a current listing of active informational and technical TSB's as they apply to the Caprice PPV. Everyone needs to understand that is up to the individual to review this list and then seek further information or guidance--the actual bulletin, or at least inquire about what is in it that may be pertinent to a vehicle issue--from a dealer or an aftermarket source such as Alldata that's licensed to distribute the information (yeah, for a fee).
Unfortunately a majority of the service information on the vehicle is copyright protected and proprietary to GM and it's subsidiaries. While we do have some files available (for instance - the upfitting & sales guides) which also may contain documents classified as a governmental "public record", we can't blanket publish all the TSB's. We like our little happy home here and very much want to keep it humming along. So, the onus is on you, the owner to be proactive once we give you the lead to see if it applies to your car and if you need to take action.
The list Bill provided me was 6 pages long. I have reviewed it and am eliminating the obvious goo & dribble (I'm sure we'd all like to hear about dealer best practices on when to submit a field product report....), but since I'm doing a manual re-type of this information you are subject to the limits of my fingers. Anything not pertinent to our operation of these vehicles is being zapped. If you need the complete list for any particular reason, I'm sure your dealer can provide more information.
List follows in next post. Enjoy! And.... everyone please thank Bill for his tireless dedication to our cars and the system!
Re: Current Informational and Technical TSB listing - 12/3/2
Post by elc32955 » Fri Dec 06, 2013 12:50 pm
CAPRICE PPV TECHNICAL SERVICE BULLETIN LISTING AS OF 12/3/2013
INFORMATION
12-06-01-003A: Information for Repairing Engine Front Cover Oil Leak, Sealing Surfaces Preparation, applying Room Temperature Vulcanizing (RTV) Sealant. 11/27/13
01-06-01-011H: Information on Engine Oil Consumption Guidelines. 10/29/13
07-08-42-011G: Police Package Vehicles, Daytime Running Lamps (DRL), Automatic Headlights (AHL), Dome and Courtesy Lamps, Trunk Release, Speed Limiter - Programmable Oprions - Obtaining Calibrations. 10/11/13
12-00-89-004A: Snow Chains now approved for Caprice PPV. 9/24/13
06-08-47-001J: Warranty, SPS, Control Module Diagnostics and Configuration Information, Programming, Set-Up. 9/20/13
07-02-32-002N: Hydraulic Power Steering System Leak - Required Diagnostic Actions. 9/18/13
99-09-40-005G: Seat Belt Extender Availability. 8/15/13
08-07-30-026B: Information on slight vehicle movement in Park at start-up after cold soak. 5/23/13
03-08-48-006I: Repair information for reconnection of Rear Window Defroster (Defogger) Contact or Tab. 5/3/13
99-04-20-002H: Information on Driveline Clunk Noise. 4/11/13
13-00-89-003: Vehicle Software Enhancements. 3/27/13
13-00-89-002: Key programming and adding keys for Caprice PPV. 2/28/13
10-08-45-001D: Information for electrical ground repair - use new replacement fasteners with conductive finish. 2/14/13
08-08-44-029C: Updated warranty and goodwill exchange program for electronic products (US and Canada). 8/29/12
07-00-89-004H: Special Equipment Options (SEO) on Police Vehicles. 6/14/12
05-03-08-002E: Information on Diagnosis and Replacement of Shock Absorber and Strut due to fluid leak. 5/31/12
12-05-26-001: Information on Resurfacing Park Brake portion of Rear Brake Rotor. 5/18/12
H12-10-05: Front End Module Replacement (Collision Repair). 5/17/12
08-08-44-028A: Information on inadvertent steering wheel control (SWC) button press causing radio anomalies. 3/30/12
01-07-30-042G: Information on 2-3 upshift or 3-2 downshift clunk noise. 9/22/11
11-06-03-001: Battery B+ Terminal Cover removal procedure. 5/3/11
TECHNICAL
09-01-39-007B: Carpet wet when A/C is on (Realign A/C Drain Tube). 5/30/13
13-08-116-001A: Aftermarket ALDL or DLC interface devices causing multiple issues. 3/22/13
12-08-64-004: Front Door window jamming half way - glass falling out of Front Run Channel. 9/14/12
12-08-44-002A: Radio Software Update - enhancements (for) April 2012. 8/20/12
H12-10-04: Wind whistle Noise from door side mirror above 50 MPH. 5/25/12
H12-10-03: Body Side Assembly Serviceability. 3/29/12
99-01-39-004D: Air Conditioning Odor (Install Evaporator Core Dryer Kit and Apply Cooling Coil Coating). 8/10/11
07-06-04-019D: Intermittent Malfunction Indicator Lamp (MIL) Illuminated, DTC P2138 with reduced engine power (Repair Instrument Panel to Body Harness Connector). 6/28/10
SERVICE & RECALL BULLETINS FROM NHTSA
PI-1088, NHTSA ID 10053844
Chevrolet Caprice 2011, 2012, 2013, 2014
Information involving improper electrical connections using the power studs on the isolation relay.
SB12-08-132-001A, NHTSA ID 10052297
On some trucks and passenger vehicles, accessory power outlets (APO) and trailer lighting are common accessed electrical systems that are affected by devices that are plugged in and become inoperative due to an open fuse and no problem with vehicle identified.
PB-12026, NHTSA ID 10045039
(Documented in previous thread)
PI-0412, NHTSA ID 10044124
PIP-4750-D, NHTSA ID 10043579
Locked
