Dissapointing Track Times
This section is for all your track and racing topics. Sanctioned events, test n' tune, competitive track & racing at public facilities, off-street drag events, it all goes in here.
G8gtl76
Post by G8gtl76 »
For some reason, I just cannot get a better time than 9.5@76 in the 1/8th. No 1/4 mile tracks near me. I can't launch good enough for anything lower than a 2.3 60ft. It just bogs off the line. Had a G8 years ago, and in stock form it ran sub 9s in the 1/8th. Is the tune that much more restrictive on this car?
Silversled
Re: Dissapointing Track Times
Post by Silversled »
I'm not a drag racer but I can tell you the stock tune sucks. It's very conservative with lots of Torque Management. The spark tables are backwards and ride on knock retard through the midrange and then decrease with RPM after max torque.
2014 Chevrolet Caprice PPV
2014 Chevrolet Stingray Z51
2016 AMG C63
2015 BMW X5 iDrive 50i
i think it has alot to do with the tq management , and being set up to limit wheel spin to a minimum
look for the no burnout topic
greasychevy
Post by greasychevy »
traction control turned off? Needs tune.
2011 9c1 Hugo Blue
Post by xcidmigs »
what gas do you have in it and how old are the 02 sensors? I had a low miles car with a lazy 02 that was pulling timing out on 87 octane no idea why, but i had no way to know that until the car was logged and someone looked at it.
greasychevy
it will pull timing on 87 no matter what. If op is on stock tune, that's why it's lazy. needs less TM, better shifts, and more fuel/spark,
2011 9c1 Hugo Blue
