G8 center with shifter and Tap up tap down shift
Maxspeed96ct
Post by Maxspeed96ct » Tue Oct 10, 2017 2:04 pm
:D I'll start with the tap shift. You need a g8 shifter, and then you run wire from pin 1 on the shifter to pin 17 on the green connector of the BCM
next you need a wire from pin 4 on the shifter goes to pin 20 on the bcm green connector .
I used part number snac-a021t-m0.64 for terminals on the BCM. The two for the other side on the shifter I got from steve walker but Ill try to get the numbers for you guys. Youll leed to barrow or buy a molex crimper tool.
No special programing is needed but the gears and sport mode do not display on the dash. Need to use your noggin as if it was a real manual (don't worry the ecu will still down shift for you as needed.
To really make your sport shifts feel sporty Id highly recommend a custom tune.
There's a few thread on the center console. I used these threads for references.
https://www.newcaprice.com/forum/viewto ... =20&t=1065" onclick="window.open(this.href);return false;
I still have yet to hook up a TC switch, just have the oem one wired in for now. The one I got was from a v6 g8 but I need the connector, I didn't think it was going to be different.
also missing some odds and ends like the piece for the passenger side handle and the cup holders.
Here are some pics so far
Ill add to this thread as I have time.
ImageUntitled by david B, on Flickr
ImageCaprice by david B, on Flickr
the shifter connector
the g8 shifter pin out
BCM green connector pin out
Maxspeed96ct
Re: G8 center with shifter and Tap up tap down shift
Post by Maxspeed96ct » Tue Oct 10, 2017 2:06 pm
center cubby in the making
91C02920
Post by 91C02920 » Tue Oct 17, 2017 12:06 am
Great to hear the TUTD works with just wiring it up!
Install looks great. I really like the cubby box you are making. I really need one of those for my car.
Maxspeed96ct
Post by Maxspeed96ct » Thu Nov 09, 2017 12:10 pm
Just to update, i'm waiting on cup holders to 100% finish.
But I wanted to share what i used for a traction and trunk button.
Got the traction/trunk button from GM parts direct 92247604 for 25$ and steve walker had the white connector.
The terminal pins are mouser part # 1123343-1
Maxspeed96ct
Post by Maxspeed96ct » Wed Nov 15, 2017 1:32 am
99% done ImageUntitled by david B, on Flickr
gregc
Post by gregc » Fri Dec 15, 2017 9:30 pm
Maxspeed96ct wrote:99% done ImageUntitled by david B, on Flickr
I've been looking for that white connector forever. Still can't find one
Post by smwalker » Fri Dec 15, 2017 11:19 pm
gregc wrote: I've been looking for that white connector forever. Still can't find one
Just realized the info on it is kind of hidden in an unrelated titled thread so some might miss it. But link to info:
viewtopic.php?f=21&t=1022&start=10#p13796" onclick="window.open(this.href);return false;
I got a bunch of the white connectors as a sample so anyone that needs one let me know. Just do not have any of the terminals, but mouser has them.
