difference between 2011 or 2012
Are there many difference's between these two years?
Re: difference between 2011 or 2012
11 no hour meter , 12 has the hour meter
pretty much it
pretty much it
I think there’s a difference in the traction control system too. I recall reading you can’t fully turn it off in the 11
yeah the 11's you cant fully turn off
12 got the knee airbags so that changes the glove compartment a little.
12 also got passenger side outside key hole,
And the Trans cooler got moved a bit in front of the radiator.
Also the rear bumper lost it's center valiance at the bottom, just a single piece bumper now all the way to the bottom.
Can the HP Tuner program disable it all together ??
not certain--I recall the rear upper control arms transititioned from stamped steel to aluminum at some point in 2012
Available colors may have had a few additions/deletions
I am pretty sure the AC compressor, AC hoses, cooling fans, radiator, condenser and the power steering cooler are different. I believe the ABS module also has a different part number.
David
David
11 has a locking glovebox also.
Mine has no logo on either key fob. Idk if that's all 11s or just mine.
1995 MG5 Yukon GT Black
FWIW when I had my key recall done, I lost the logo on my keys. 2012.
