ABS and Stabilitrak faults
Newb_1969
Post by Newb_1969 » Tue Sep 17, 2019 9:02 pm
Hi everyone! My name is Derek and I’m in my first 24 hours with my new 9 c1, and I’m a little concerned already. Stabilitrak and ABS lights are on, and I can not turn Stabilitrak on or off with the button on the shifter. I replaced the f5 and FU3 fuses, but it appears they were both good. I just called the guy I bought the car from and he said to change the breaks (said they were new yesterday) and that will fix it. Gonna try to get codes off it later, but does this scenario sound familiar to anyone? Thanks in advance for any ideas you may have.
Fudgehog
Re: ABS and Stabilitrak faults
Post by Fudgehog » Tue Sep 17, 2019 9:38 pm
Get it code read. Could be a wheel speed sensor or just might need a brake position relearn done with a Tech2.
I would suggest you get a good code reader/programmer. The cheapest one with Tech2 functionality is the VXdiag.
03 Silveraydo 4.8L
13 Caprice 6.0L, Solo catback exhaust, 3.27 diff, VCM OTR
Newb_1969
Post by Newb_1969 » Wed Sep 18, 2019 1:01 am
Thanks for reminding me to do a good signature!
Copy that, I cant seem to find a retail store that has one. (I wanted it tonight) Amazon is my fiend.
Thanks! I'll let you know how it goes.
Post by CrashTestDummy » Wed Sep 18, 2019 6:53 pm
When I had the ABS light come on on our '12, I ended up getting the Blue Driver unit. It at least reads the ABS stuff. I think it will also read the stabilitrak stuff, too, but haven't had to get that deep into it. I downloaded the app to our Galaxy Tab 4 tablet. Works quite well.
I think we knocked a piece of corrosion loose in the socket the left rear wheel speed sensor fits in, as I pulled a wad of dirt/rust out with a pair of tweezers when replacing the sensor. Probably knocked it loose in an autocross event we ran the car in a few days earlier. :shock:
But those lights can be set by silly stuff, like a failing battery of loose/corroded cable ends. A failing alternator can do it, too. Heck, the PO could have set the things off doing a last drive in it hooning it around a bit. Usually everything goes back off on a subsequent restart, but not always.
2010 Tahoe PPV (her car)
Newb_1969
Post by Newb_1969 » Mon Sep 23, 2019 8:49 pm
Autocross event?!?! Wow! Yeah, I'm still waiting for the Tech2 reader to come in from amazon. My brakes were good all around, and fluid is good. The brakes work great, but the light is annoying. Thanks for your help! I will update once I have something.
Derek
2012 9c1 L77
bone stock
