spark plug change
cerbomark
spark plug change
Post by cerbomark »
What do you all know about the idea of changing spark plugs on a 50K mile car with 250 hours TOTAL idle time. Guessing about 1500 hours running time. Runs good. Is it worth the time and money. I am aware I think GM calls for 100K. Everything else on the car has been maintained way ahead of required time? Thanks.
2016 C1
Re: spark plug change
Yea really not worth it. You can pull a few and inspect but you will find no wear to speak of. Rule is wait till 100K or if you get a misfire before that replace them all.
Sanford
Post by Sanford »
With that mileage along with the low hours, I would say it would be a waste of time and money.
David
the original ac delco platinum id change around 50k , when GM farmed out plugs to ngk and irridium , they were alot better plug
i think the current are champions , and not much experience with them
but overall around 50k id look them over , and from there 15-20k
Like most of the others, I'd say not worth it unless you're chasing an issue. Had a slight vibration at idle on our '10 Tahoe with, at the time, about 85K miles. I did plugs and wires while changing the oil. The plugs all looked great. The new plugs and wires made zero difference in the way the truck ran.
cerbomark
Post by cerbomark »
Thanks all, I heard enough and will leave it alone for now.
2016 C1
