Another option if you have a 2014+ with the 26mm bar is the Nolathane REV004.0228 Black Sway Bar Mount Bushing.
It’s a greaseless design with an interior PTFE coating
South Cackalacky
2014 Caprice PPV
2005 Pontiac GTO
1998 Lexus SC400
2014 Caprice PPV
2005 Pontiac GTO
1998 Lexus SC400
Threw on some new rims. 18” camaro take offs I picked up
- B2C160A2-2426-4D4E-9C41-8B605AFEB0B0.jpeg (3.36 MiB) Viewed 7818 times
Looks good, I have a set of those with no tires. Are they the stock Camaro size tires, or did you move the ppv tires over?shawnjon82 wrote: ↑Sat Oct 10, 2020 1:09 pm Threw on some new rims. 18” camaro take offs I picked up
I switched my TPMS sensors over along with my Goodyear tires that still had about 80% tread life
Coolshawnjon82 wrote: ↑Sat Oct 10, 2020 6:25 pm I switched my TPMS sensors over along with my Goodyear tires that still had about 80% tread life
Replaced my struts and added replaced my stock springs with ss takeoffs
- IMG_20201022_175244.jpg (3.97 MiB) Viewed 7591 times
2014 Caprice
Tsp LS3 stage 1 cam
3400 circle D converter
3.27 Camaro diff
Hoosier dr2 drag radials.
11.86 at 117mph
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
Good looking setup, what size wheels and tires are you running and are you having any tire rubbing issues when car is loaded down .
Thank you for your time.
Pat
2013 Chevy Caprice PPV, 9C1, L77, 3” Solo exhaust, Baer 6 piston front calipers, 2nd gen. CTS -V sedan wheels , BMR sway bars and end links
I added the factory LATCH brackets to the backseat after they finally came off backorder. Didn't take any pics, but if someone else is searching the brackets use six m8x1.25 nuts to hold them in along with the middle two seatbelt buckle brackets. The car seats are way more secure now.
Stock tire size with 32mm offset wheels, the wheel offset is not ideal but they were cheap and came with snow tires. I haven't had any rubbing and I've thrown it through some pretty wicked corners. But I could see them rubbing with enough weight.
2014 Caprice
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
I put wheels and tires on her since she was clean. Trying to get a pic to upload. Not working os great so bear with me.
Mike Baz
____________________________________________
2012 Chevrolet Caprice PPV - Phantom Black Metallic
