gto's use a fixed key blade that is held in by 2 screws to the tortoise shell remotesmwalker wrote: ↑Thu Sep 24, 2020 4:56 pm They did not give much info in that listing but one thing you need to look out for is the key blank style.
It seems all the sellers on Ebay list our cars and the G8 as compatible with a HU43 key blade. When in reality our cars and the G8 come with a GM45 key blade. Slight difference so maybe they are compatible and will work either way but I am not sure so I just thought I would point it out. Seems the HU43 came factory in the GTO's so not sure if the sellers are just assuming compatibility in later years with all Pontiac's from AU??
http://i.imgur.com/UZNOk89.png
coded vs uncoded key
Re: coded vs uncoded key
They may use a different style head but they used a HU43 Blade correct?
not the best pic , the 2 outters say GM57 , and ive got no history on those keys , the center ive had since 06
the 57s have smaller notch on the non-cut side , but as far as i know the blade was the same 04-06 , the 57's are from 2 05s
- DSCF1325.JPG (3.29 MiB) Viewed 4416 times
Does anyone know where the immobilizer is (or should be) in the attached picture? My car starts with just the "part with key blade" which makes on think the immobilizer is on that part but I can't find where it is. I've picked and probed the part but to no avail. My research indicates it is likely very close to the base of the blade of the key. I suppose a previous owner may have taped one inside the steering column (column shows evidence of disassembly).
I'm all hung up on getting a flip key working mostly b/c I really want remote start capabilities.... I understand I need BCM work among other things (like a new key fob). Maybe I'll just buy the 50 dollar set mentioned in previous post and roll the dice.
- disassembled key Caprice.jpg (5.75 MiB) Viewed 4402 times
Holy cow! Perfect. Just what I was looking for. Thanks - John.
