2013 ppv 9c1 shifter bulb
Mpotsie84
Post by Mpotsie84 »
Could anyone explain the process to changing the shifter bulb or if it even has one? Thanks
Re: 2013 ppv 9c1 shifter bulb
Service manual just sows the 9C3 shifter: https://www.chiltonlibrary.com/content/ ... 947043.pdf
Bulbs are $16 a piece, I think because they are LED.
Pair of them not quite clear where they are but should be able to follow the harness:
https://chevrolet.7zap.com/en/caprice/4 ... 20-0-0/#11
If they are LED hard to imagine they burnt out?? Have they ever worked in yours? Does the light ring around the key light up in the column?
GM charges quite a bit for bulbs , not sure why when they are usually bulk items and sold 1 by 1
Mpotsie84
Post by Mpotsie84 »
Im gonna take it apart and see if it even has bulbs in it after work. I also Have to try to figure out why the high beams wont work. Theyre currently operated by a toggle switch on the dash and I'd like them to work as they should off the turn signal lever. I'm guessing they cut some wires after it left fleet.
DapperDanMan
Post by DapperDanMan »
I saw one bulb in there earlier today for sure.
2015 Caprice 6.0
