Oil Pan Removal
Draven8795
Oil Pan Removal
Post by Draven8795 »
Seems like there's enough clearance to get the pan out without doing much on these cars. Needs a new pan gasket. Anything I'm missing that would require the engine to be raised up or the steering rack to be moved?
119C3NJ
Re: Oil Pan Removal
Post by 119C3NJ »
Remove nuts off motor mounts. lift engine 2" shove some blocks in to support it. remove pan. drill rivets, replace gasket, new rivets and reinstall. not bad job at all.
1995 MG5 Yukon GT Black
Draven8795
Re: Oil Pan Removal
70ft lbs from the trans through to the oil pan seems way excessive? Anyone know if that is correct?
Re: Oil Pan Removal
what ?
Draven8795
Re: Oil Pan Removal
Tighten the two transmission bellhousing bolts to 37 ft. lbs for a manual transmission and 70 ft. lbs for an automatic
transmission.
Re: Oil Pan Removal
Post by xcidmigs »
Draven8795 wrote: Mon Oct 19, 2020 12:45 pm 70ft lbs from the trans through to the oil pan seems way excessive? Anyone know if that is correct?
It is and the # listed for the pan bolts is also, I snapped 1 thinking it couldnt be as low as it is. Be carefull
Fandango
Re: Oil Pan Removal
Post by Fandango »
70 in-lbs or 70 ft-lbs?
That's huge torque.
