Budget g8 headers
Re: Budget g8 headers
id maybe think of trying the 5th gen camaro headers , since they also have a engine oil cooler
ive been trying to get pacesetter to build the SS and caprice headers , and no luck and i work there
Camaro oil cooler is in a different location by a few inches. It sits farther forward on the motor and is less in the way of the exhaust. It's possible that it might work but also might not
space from the oil pan out is where im thinking , not the front to backfuzzkill wrote:Camaro oil cooler is in a different location by a few inches. It sits farther forward on the motor and is less in the way of the exhaust. It's possible that it might work but also might not
Left side Kooks on the Caprice
- KIMG0293.JPG (140.28 KiB) Viewed 15767 times
- KIMG0294.JPG (132.29 KiB) Viewed 15767 times
2011 9C1 6.0
Flex fuel tune
Flex fuel tune
Is it just me or does that now look like you have a oil heater? Is that giant brick designed as the heat sink like to get rid of heat in the oil? Looks like its surrounded by the header tubes now.
It's not cooled by air- the cooler has engine coolant circulated through it.xcidmigs wrote:Is it just me or does that now look like you have a oil heater? Is that giant brick designed as the heat sink like to get rid of heat in the oil? Looks like its surrounded by the header tubes now.
2011 9C1 6.0
Flex fuel tune
Flex fuel tune
Would Header wrap help in this application?
2014 Caprice PPV silver
2017 Ram 3500
2002 CETA trans am
1995 9c1
1977 Trans am SE 4spd.
1978 trans am 400 4 spd.
2017 Ram 3500
2002 CETA trans am
1995 9c1
heat shield is better , but yes it would help some
what about wrapping the oil cooler parts themselves if thats no a heat sink might help insulate it from becoming one. I've always heard header wrap isn't the best for their long term survival....
that defeats the purpose , the cooler while liquid to liquid , it also uses the air to remove some heatxcidmigs wrote:what about wrapping the oil cooler parts themselves if thats no a heat sink might help insulate it from becoming one. I've always heard header wrap isn't the best for their long term survival....
