Pursuit wrote: And those headers tuck in there nice!
Regards,
Agree, I was surprised at how well it fit considering some of the installations I've seen which appear to hang low. Some have claimed they had to space out the "cross brace" or delete it. I'm not sure if it's because the kit is designed for a 2014 SS which essentially has the same chassis as the 2014 PPV or if I took extra care to tuck it up before tightening the clamps.
I've driven it quite aggressively already and no issues with the pipes hitting the chassis. I'm happy with the fit.
2014 Chevrolet Caprice PPV
2014 Chevrolet Stingray Z51
2016 AMG C63
2015 BMW X5 iDrive 50i
Regards,
just make sure you crawl under it soon and double check all the clamps are tight
i usually check the first few heat cycles for a few days , then after a week , ive seen them work loose , and that is usually where the hitting comes in , also some dont get it right the first time
After doing some WOT tuning this weekend the mid-pipe would sometimes barely touch the cross brace and buzz for a split second. This really only occurred when letting off and then immediately on the throttle when at full engine load.
The mid pipe is already tucked up as far as I would like. I decided to go to the local Ace hardware and pick up 3/8 steel spacers and longer flanged bolts of the same 10.9 grade to space out the cross brace a tad.
Now there is plenty of clearance and no rub whatsoever.
2016 AMG C63
Heh, time to find some polyurethane engine mounts!!
Nice solution. I'll be keeping that in mind when I throw my exhaust system under our '12.
Should have painted that cross brace!
CrashTestDummy wrote:Heh, time to find some polyurethane engine mounts!!
LOL. A loud car I don't mind; a vibrating car I do.
I thought of painting it but I'd rather drive than watch paint dry. Also for the effort and a $10 rattle can, I'd rather spend an extra $45 for a BMR brace and look all race-boy like BMR is about 30 minutes from my house.
2016 AMG C63
