Yesterday was an expensive day... DOD Delete adventure
Well last week I started getting really bad lifter noise on the passenger bank of my 2011 9C1 with 106,000 miles so I started tearing the engine bay apart and yesterday I bought everything I need from BTR. I'll be sure to post a bunch of pictures when I'm done as I have been taking a ton of pictures as I go. As of right now my plan is to keep the cam pretty mild since its my daily driver that my wife also drives occasionally. Here's what I've got planned so far;
Take the heads off and have them milled 0.020 to 0.025" to bump the compression slightly.
Install Smith Brothers Bronze Bushing to replace the needing bearing trunnions.
Do the normal DOD delete with Chevy performance LS7 lifters and ARP hardware.
Install EPS truck camshaft as it gives a nice wide power curve with a decent bump in power to compliment the higher compression and most importantly mild manners. PN
EPS31826132.
BTR platinum spring kit to match the camshaft
BTR Pushrods 7.375"
Camshaft installation kit with all the gaskets, ARP hardware, LS2 dampner, new timing chain, and camshaft sprocket for 3 bolt.
ATI Harmonic balancer for the G8 no UD.
Along with that I am installing an engine pre-oiler that every time the engine is started it pre-oils the entire rocking and rotating assemblies to eliminate the dry start wear and piston slap.
Again I will post pictures and probably put together a PDF document of the adventure as this is the first V8 motor I've done this with. Everything else has been smaller engines or I didn't get quite this deep into the V8
EPS31826132.
BTR Pushrods 7.375"
Re: Yesterday was an expensive day... DOD Delete adventure
Sounds like a pretty good plan. I also milled my heads 0.025". I'm amazed that more people don't do this. I don't think the pre-oiler is necessary, and it won't do anything for piston slap. Do you actually have piston slap at startup?ABrandenburg wrote:Well last week I started getting really bad lifter noise on the passenger bank of my 2011 9C1 with 106,000 miles so I started tearing the engine bay apart and yesterday I bought everything I need from BTR. I'll be sure to post a bunch of pictures when I'm done as I have been taking a ton of pictures as I go. As of right now my plan is to keep the cam pretty mild since its my daily driver that my wife also drives occasionally. Here's what I've got planned so far;
EPS31826132.
BTR Pushrods 7.375"
kevink~ yes I have pretty pronounced piston slap at start up and as soon as I get oil pressure it goes away. Even if the pre-oiler doesn't eliminate it, its cheap insurance and provides lube to all the rotating assemblies before start up. Yeah I'm surprised that more people don't mill the heads when doing the DOD delete, its fairly cheap and gets the compression back where the engine likes to be. Maybe because people still like to be able to run E85 but I don't run anything less than 91 in my muscle type cars so its kinda pointless for me.
kinda funny the wrist pins and pistons are not oiled , id guess you are getting a lifter that bleeds down and clatters at start up
make sure you replace the lifter trays
That doesn't sound like piston slap. Piston slap goes away as the piston warms and expands, reducing piston to wall clearance. It has nothing to do with oil pressure. It happens quickly, but not as quick as oil pressure comes up. My 4.8L truck with 170,000 on it has done it since new. It takes about 300 feet of driving to get enough heat in the piston to stop the slap. I think you have another problem.ABrandenburg wrote:kevink~ yes I have pretty pronounced piston slap at start up and as soon as I get oil pressure it goes away. Even if the pre-oiler doesn't eliminate it, its cheap insurance and provides lube to all the rotating assemblies before start up. Yeah I'm surprised that more people don't mill the heads when doing the DOD delete, its fairly cheap and gets the compression back where the engine likes to be. Maybe because people still like to be able to run E85 but I don't run anything less than 91 in my muscle type cars so its kinda pointless for me.
When I took it to a motor shop and said I thought it was the piston scuffing, they told me it was piston slap from loose tolerances... whichever it is I probably won't get rid of it, but the pre oiler isn't going to hurt anything either. I'm definitely replacing all of the top end components, I just didn't list the lifer trays separately.
thats a nice cam, they do suggest using a slightly higher TC with that on a 6.0 in a truck application, doesn't sound like you are doing that now, wonder what it will launch like? Can I suggest an oil catch can since you are into 1) performance 2) PM/peace of mind. I'm amazed what mine poops out.
xcidmigs wrote:thats a nice cam, they do suggest using a slightly higher TC with that on a 6.0 in a truck application, doesn't sound like you are doing that now, wonder what it will launch like? Can I suggest an oil catch can since you are into 1) performance 2) PM/peace of mind. I'm amazed what mine poops out.
I had looked at one but wasn't really sure what the purpose was? Where is the oil getting into that it's cause problems?
You'll only really need one if you get oil ingestion into the intake tract. Not all cars get it, and you can always add that later if you see a fair amount of oil behind the throttle plate.
What pre-oiler are you using? Accusump?
CrashTestDummy wrote:You'll only really need one if you get oil ingestion into the intake tract. Not all cars get it, and you can always add that later if you see a fair amount of oil behind the throttle plate.
Autoenginelube.co, its a smaller shop that my dad and I have used in the past buying kits for farm equipment and vehicles and we were always pretty happy with the results. I haven't bought or used one in years though so I'm hooping that the quality has remained the same.
