Hey guys,
I am wanting to put Camaro SS Brembo brakes on the front and rear of my PPV. I thought that I saw somewhere in this forum that someone had suggested it and listed the parts required to do so, but I can't find the topic. I have found the one about the CTS-V upgrade, but I wanted to compare the two swaps to see if there is anything to look out for. I have the calipers, rotors, and plan to purchase the SS flex hoses. Can someone help me out?!!
Thanks in advance.
Brake upgrades
Brake upgrades
Owner of Lemar Auto Designs
1986 Chevy Caprice (sedan)
1984 Chevy Caprice (coupe)
1996 Chevy Impala SS
1986 Monte Carlo SS
1984 Monte Carlo SS
1986 Monte Carlo SS
1984 Monte Carlo SS
Re: Brake upgrades
for the rear , you use the 15-17 ss sedan rotors
front are 5th gen camaro , 09 g8 gxp , 14-17 ss sedan rotors
i think other than the bolt size for the front calipers , some being 12mm and some 14mm , they are all the same
the rears you have to make sure of their side , i think v's mount on different and need to be flipped , and the 5th gen camaro are fine , along with the 15-17 ss sedan
- Administration Staff
Re: Brake upgrades
for stainless hoses, do not use the Russell kit, wrong fitting spec
TechnaFit PN4500 is made to fit--brackets need to transfer from stock front hoses, with minor modification, or I can work with you on a bracket swap.
Re: Brake upgrades
Is it not possible to reuse the PPV hoses? I didn't see that posed in earlier threads? Or reuse Camaro SS stock hoses in their place? I'm just trying to see how cheaply I can get away with doing this...
Re: Brake upgrades
yes, stock hoses should work, but the OP specifically mentioned he wanted to use the stainless hoses, and it was an opportunity to provide some background on the subject
Re: Brake upgrades
Well, technically, the OP wrote ‘SS’ hoses, which in this acronym-overloaded world could mean ‘stainless’, OR ‘SS’, which would be an acronym for ‘Super Sport’, ‘Sad Sack’, ‘Super Soaker’, or any number of other list of words.
