Mud flaps part numbers.
Re: Mud flaps part numbers.
So the part numbers for the front I used are 92277966. It says they fit a VE base holden, but I spent about 4 hours compairing pictures and numbers and using crazy pauls old site list. I found some that seem to work. I will post up pics when they are mounted.
Dont' mind the messy car.
- mudflap3.JPG (100.41 KiB) Viewed 13302 times
2014 Caprice PPV silver
2017 Ram 3500
2002 CETA trans am
1995 9c1
1977 Trans am SE 4spd.
1978 trans am 400 4 spd.
2017 Ram 3500
2002 CETA trans am
1995 9c1
Since the PN on our index is for SS's, my question is does the SS front mud flap fit the Caprice?
I know the rears fit but would this kit work as well?
https://m.ebay.com/itm/GENUINE-HOLDEN-M ... 2130830445" onclick="window.open(this.href);return false;
Active Duty USAF
Active Duty USAF
No, the fronts do not because of the ground effects on the ss/g8 is larger.
2017 Ram 3500
2002 CETA trans am
1995 9c1
2017 Ram 3500
2002 CETA trans am
1995 9c1
So what about the ebay set? Can you point me to front ones that work?
Active Duty USAF
Active Duty USAF
I I’ll see if I can find my part number list. I had to get mine from AU.
2017 Ram 3500
2002 CETA trans am
1995 9c1
2017 Ram 3500
2002 CETA trans am
1995 9c1
Right that ebay posting is from Australia. That's why I was asking those rears are the same or at least look the same as the rear PN posted on the index.
Active Duty USAF
Active Duty USAF
the numbers I used for the front are
92254221
92254222
They came from Holden in AU. I couldn't find them on ebay .
the second picture in this thread, is the ones you have listed in the enay link, you can see they do not fit.
92254221
92254222
2017 Ram 3500
2002 CETA trans am
1995 9c1
2017 Ram 3500
2002 CETA trans am
1995 9c1
http://www.ebay.com.au/itm/Genuine-GM-H ... 2688695620" onclick="window.open(this.href);return false;
Here is the fronts I used. Great fit. I might order another set just to have.
2017 Ram 3500
2002 CETA trans am
1995 9c1
2017 Ram 3500
2002 CETA trans am
1995 9c1
those fit our side skirts ?
Revisting an old topic here...
It’s too late, I’m too tired, too old or all three but I could not follow what part numbers the Holden mudflaps finally ended up being and where to get them. It seemed the topic bounced around quite a bit and there were several conflicting posts (at least to me). For a 2012 9C1 in case that makes any difference.
Oh and where to get them?
Thanks!
Thanks!
2012 9C1 (L77)
2008 Suzuki B-King - 2nd gen 1340cc Hayabusa engine - Scorpion exhaust
* (Bequeathed to me by Chris Hibbard 11/11/1958-01/08/2011 — The HibbsCycle) *
#ABG (Always Be Gamblin’) http://www.Gambler500.com" an impractical vehicle-off road-navigational challenge...
