I have saved up some more money and purchased 95% of the parts I need, I have them listed below.
I also purchased the connector for the T/C & Sport mode switch using part numbers found on the post
below along with the Center Bezel. I am going to try do without the center support and see if it works. I also have the part numbers that you can purchase the parts on any GM OEM parts site.
https://www.newcaprice.com/forum/viewto ... =20&t=1065" onclick="window.open(this.href);return false;
Center Bezel: 92268703
T/C Sport Mode switch connector: 13585868
Center Console Upgrade Round 2
- tedwards0633
- Found this passenger window switch on eBay for $40. I will strip and wrap in vinyl to replace the center switch that would normally go in the middle of the center console bezel. I will send a picture once I complete.
- s-l16001.jpg (4.26 KiB) Viewed 7564 times
- Found this on eBay for $10. I will run this with the radio upgrade from White Auto. I will install this in the center console compartment.
- s-l1600.jpg (6.84 KiB) Viewed 7564 times
- Found this on eBay for $56
- s-l16001.jpg (2.74 KiB) Viewed 7564 times
Re: Center Console Upgrade Round 2
How do I contact Crazy Paul about this console part? And where did you get the part where the window switches go? Thanks
ANy reference you see to Crazy Paul will be a bit old as he is not in business any longer.
Sadly, yes. Contact Karo and see what he can do for you. He may have stuff in stock.smwalker wrote:ANy reference you see to Crazy Paul will be a bit old as he is not in business any longer.
