2014 PPV front end noise
Hello and thanks for taking time to read this.
Just received my 2014 Caprice ( GovDeals purchase), a quick turn around the block and backing it into the driveway reveals a substantial front suspension noise, obviously it will get checked out over all, but, what might be the most likely cause? 122k miles from South Carolina.
Thank you!
Thank you!
Re: 2014 PPV front end noise
I've had to replace the stabilizer links twice in my car, apparently that's a weak spot....they definitely make noises when bad.
Steve Robin
Minneapolis, MN
'11 PPV 9C3 Phantom Black Metallic
Minneapolis, MN
Thank you Sir, those do go away, it will get a thorough going over soon, this is my first PPV, so am looking to learn where the weak spots are.
Thanks again for replying!
same with me links and strut mounts i would use GM parts i had one Moog strut mount come apart after 4 months
do not use the OE mounts , they are junk
use these - https://holdenpartsusa.com/collections/ ... -g8-ppv-ss
Indeed. OEM strut mounts are a bit soft, and tend to settle with time, resulting in a rattle when the suspension moves up and down. I'd usually recommend OEM replacements, but not in this instance. Whiteline is the way to go.s/c'd cav wrote: ↑Sun Jan 13, 2019 3:29 am do not use the OE mounts , they are junk
Thank you for your informative replys!
Struts and mounts replaced, noise less pronounced but, still popping, what else might it be?
did you do anything with the sway bar end links ?
Depending on the magnitude of the bump you're going over, and the speed at which you take it, you can still get the strut top bushing to compress enough to rise off the body and 'pop' when it drops back down on the upper strut mount.VintageIron41 wrote: ↑Mon Jan 28, 2019 11:40 am Struts and mounts replaced, noise less pronounced but, still popping, what else might it be?
Failed motor mounts can also cause some rattling or popping noises.
