Lucy (2011 Caprice) gets a supercharger
Im in the process of installing a LSA supercharger on my 2011 Caprice (Lucy) Im using as many new Gm parts as I can. They are not that much more than used one when you are buying from www.gmpartswarehouse.com. I am a GM technician and they even beat my employee prices! I have most things collected based on "Silversled"'s great write up of his LSA install. I still have a few big things to figure out like
What Intake/air cleaner to use?
What injectors to buy?
and Why does everyone seem to install LSA valve covers?
Any help/advice would be appreciated!
I plan to post pictures and prices I paid to help others
Re: Lucy (2011 Caprice) gets a supercharger
Lucy
- 71147134_519817058804428_4065154732841238528_n.jpg (199.74 KiB) Viewed 8946 times
- 80645953_2222410068052032_6749060885370634240_n.jpg (28.79 KiB) Viewed 8946 times
installed the idler pulleys for the supercharger belt
- 80323659_738892979936461_2326128818357534720_n.jpg (40.25 KiB) Viewed 8946 times
- 80223255_777829386050680_2429607336571043840_n.jpg (35.54 KiB) Viewed 8946 times
I believe jegs was running a sale i order the fuel line from them
the supercharger had a 300 dollar core charge so it came out to a little more than $1800 it came with the actuator and lines so i didn't need to order them (looking into returning them)
- Screen Shot 2019-12-25 at 11.23.20 AM.png (43.64 KiB) Viewed 8945 times
- Screen Shot 2019-12-25 at 11.23.03 AM.png (48.15 KiB) Viewed 8945 times
- Screen Shot 2019-12-25 at 11.22.42 AM.png (10.19 KiB) Viewed 8945 times
- Screen Shot 2019-12-25 at 11.22.12 AM.png (60.04 KiB) Viewed 8945 times
some of the aftermarket items
im not really sure if i needed the solid isolator.But i saw most people doing it so I guess ill jump on the band wagon
- Screen Shot 2019-12-25 at 11.29.38 AM.png (446.85 KiB) Viewed 8944 times
- Screen Shot 2019-12-25 at 11.30.15 AM.png (369.06 KiB) Viewed 8944 times
- Screen Shot 2019-12-25 at 11.30.55 AM.png (235.88 KiB) Viewed 8944 times
- Screen Shot 2019-12-25 at 11.31.28 AM.png (28.08 KiB) Viewed 8944 times
the iat breakout harness is from summit the other harness extensions are from ebay
- Screen Shot 2019-12-25 at 11.37.01 AM.png (30.86 KiB) Viewed 8943 times
- Screen Shot 2019-12-25 at 11.37.55 AM.png (229.04 KiB) Viewed 8943 times
- Screen Shot 2019-12-25 at 11.38.29 AM.png (200.72 KiB) Viewed 8943 times
- Screen Shot 2019-12-25 at 11.38.50 AM.png (25.19 KiB) Viewed 8943 times
f
- Screen Shot 2019-12-25 at 11.36.25 AM.png (206.95 KiB) Viewed 8943 times
1
- Screen Shot 2019-12-25 at 11.51.24 AM.png (40.88 KiB) Viewed 8943 times
the reason for the LSA valve covers is so the coils clear the s/c , i dont remember if they actually hit , or if its just added clearance room
I plan to use the unused power feed for the cylinder deactivation to power my intercooler pump relay
I also plan on running the wiring harness on top of the supercharger snout it fits so much nicer and it will keep it away from heat.
- 83193537_1118944251796507_553792112483631104_n.jpg (116.19 KiB) Viewed 8747 times
