Sound Off Caprice Head Light Flashers
Post your Caprice PPV parts & components for sale here.
Acceptable items for posting include OEM new/used replacement parts, aftermarket parts, salvage yard parts, maintenance/repair tools & tooling, service publications, programming equipment, and misc. items for Caprice PPV cars. This forum is moderated, posts from members with less than 5 forum posts may be removed. Any questions please contact a moderator. SPECIAL NOTE - We have no role or liability in any transactions other then to provide a venue to advertise the items. Disputes must be resolved independently between the parties involved in any transaction.
JRWolff
Post by JRWolff »
If anyone is looking for a new WigWag Module, a company called LSH Lights (lshlights.com) has 4 of them in their Red Tag Specials for $45 each including shipping. These are the plug and play modules that KERR originally used in our cars. Part No. ETHFSS-CP
Twin 2012 9C1's
1991 GMC Syclone
1986 Buick Grand National
1rbaja
Re: Sound Off Caprice Head Light Flashers
Post by 1rbaja »
Do you need some sort of switch to activate the flasher?
It says plug and play
I put it on but how do they turn on?
Post by xcidmigs »
Yes it requires a switch the plug in part is just the piece he is referring to goes up front by passenger side headlight then requires a connection of two wires to a on/off toggle. Many threads already on how to install.
1RBaja, you should already have a wire pre-wired to activate them. All you need to do is find the wire in the interior compartment up-fitters harness and send 12 volts to it through a switch and they will activate.
And while that's a good deal for a new module you could probably get one cheaper from anyone parting out a PPV. But they are not Bendin ya over or anything. Buy it up we can walk you through hooking it up.
1rbaja
Post by 1rbaja »
Awesome thanks
Where can I find the up fitter harness?
Is it under center console?
Sanford
Post by Sanford »
If you have a 11-13, the upfitter harness came tucked up behind the glove box. It may also be tucked under the floor mat by the upfitter. There should be a dark green with a red tracer that should do the job of controlling the wig-wag module. Just need a switch to send power to the green w/red tracer. It is a small gauge wire.
David
1rbaja
Post by 1rbaja »
Mine is a 2014
Sanford
Post by Sanford »
I would gamble the 14 has the same color wire and is in the same area. I have pulled the LEO equipment wiring out on several 11-13’s, never a 14.
On the 14 + the upfitters options harness harness comes out from the front of the center console. The AUX power harness comes in from the back of the center console. Looks like you are looking for a solid green wire to apply 12 volts to.
From the 2014 technical guide located in the website files section: http://www.newcaprice.com/files.htm
14 wig wag.png (472.75 KiB) Viewed 6770 times
14 wig wag 2.png (203.9 KiB) Viewed 6770 times
