1/4 mile with Mod List
This section is for all your track and racing topics. Sanctioned events, test n' tune, competitive track & racing at public facilities, off-street drag events, it all goes in here.
BarryM
Post by BarryM »
First Time at the track with my Caprice PPV:
1.73 60'
7.85 @ 88.1 1/8
12.32 @ 110.7 1/4
155K mile short block and transmission - PPV Steel Rims
Camshaft TSP Stage 1 LS3 N/A Camshaft 225/236 .629"/615" 114 LSA, 109 ICL
Texas Speed and Performance CNC Porting and CNC Valve Job of # 823 factory heads
TSP DOD Delete
Camaro 6L80 deep transmission pan and wide mouth filter
Torque Converter - Precision Industries 3600
3.27 Limited Slip Differential
Kooks Headers, No catalytic converters, 2.5” SOLO exhaust
Roto Fab Cold Air Intake
Hoosier DOT Drag Radial Tires 245/40-18
PB1117SS - PowerBond Race Performance Harmonic Balancer
Oct 23.jpg (83.17 KiB) Viewed 8842 times
First time track.jpg (370.07 KiB) Viewed 8842 times
BarryM
Re: 1/4 mile with Mod List
Post by BarryM »
Update - Improvement
Charles Barber tweaked, thanks sir !
Increased tire air pressure to 26
1.68 60'
7.73 @ 88.9 1/8
12.13 @ 112.7 1/4
Second time track.jpg (204.95 KiB) Viewed 8755 times
BarryM
Post by BarryM »
kevink
Post by kevink »
Nice work. You can probably knock off a tenth or two with skinnies.
You can probably knock at least half a tenth going with a wheel that's NOT the Caprice wheel. Those things are heavy, and going with even a different steel wheel will cut some rotating mass. Aluminum would be even better.
Turbopowered68
Post by Turbopowered68 »
BADASS
2014 Caprice V8
1986 GN
1968 Chevelle
Nate68c10
Post by Nate68c10 »
Personal best last weekend at Cleetus and cars Indy
Tsp stage 1 LS3 cam
Circle d 3400 converter
Solo exhaust and jba long tubes
Camaro 3.27 diff
Hoosier dr2 drag radials
100 HP wet nitrous shot out of the hole
2014 Caprice
Tsp LS3 stage 1 cam
3400 circle D converter
3.27 Camaro diff
Hoosier dr2 drag radials.
11.86 at 117mph
Nate68c10
Post by Nate68c10 »
2014 Caprice
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
GammaFlat
Post by GammaFlat »
Great times Nate. How does all that grunt translate in terms of drivability? Does it feel good stoplight to stoplight?
Nate68c10
Post by Nate68c10 »
It's pretty good stoplight to stoplight. I need to have my tuner adjust some stuff around 45-50 mph but other than that it's pretty normal just bucks a little bit at that one speed range.
2014 Caprice
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
