You should be able to read the part number of the rear strut with a small mirror and a flashlight while the car is on the ground. The number should be below the lower spring support, facing outward.
Since my post on page 5, I have acquired a 12 and 13. After driving one or the other to work for a couple of weeks, when I get into a 11, I want to turn around and park it.
One of these days, I will get around to putting some low mileage surplus 13 front struts on the wife’s car.
David
SS Sedan Springs under the 2011 Caprice PPV
Re: SS Sedan Springs under the 2011 Caprice PPV
Just making sure I read all this right.Navy Lifer wrote: ↑Wed Jul 01, 2020 9:58 am
REAR
https://www.rockauto.com/en/moreinfo.ph ... 73&jsn=434
FRONT
https://www.rockauto.com/en/moreinfo.ph ... 73&jsn=435
If I get my grubby hands on some SS springs these are the struts recommended ? Do the SS springs fit on the stock struts or do I need these to make them work? Are these a direct bolt on ?
2011 Chevy Caprice
6.0
26k mile purchase
2nd owner
the voices say I am special
6.0
26k mile purchase
2nd owner
- Administration Staff
The SS springs - regardless of model year sourced, 14-17, will fit PPV OEM shocks/struts.
For all the work involved, better to renew the shocks/struts while it's apart - the 2011 PPV was still a work in progress, and OEM introduced better shock/damper valving calibration mid-production cycle. At 11 years old, the better approach includes using these Monroe parts or the OEM service replacements, if still available, along with the SS springs, which make a good bit of difference on their own, but it's the combination of the springs & less-harsh valving that really makes the car much more pleasurable to drive.
Without a further discussion of wheel/tire choice (18 vs 19 vs 20) and sidewall stiffness, the other thing needed is to re-set tire pressure to 35-36 PSI at all 4 corners, as stated in the 2011 Owners Manual. This provides a greatly-improved ride, at least with 18" wheels. TPMS won't like it, and you might get nuisance alarms when cold weather drops the start-up inflation, but the system CAN be reset to continue to function at a lower threshold point - just have to find the right tech able & willing to do it....it is NOT illegal or dangerous to change TPMS alarm setting. I don't recall the exact setting we used, but it's 28-30 PSI, still plenty of safety margin & warning before a tire is in danger or car performance is compromised.
The Monroe Australia parts listed are equivalent to the OEM service parts - both are made in Australia, same source, just different PN's. Not able to say if valving specs are the same, but they aren't drastically different. These parts are for 11-13 only, as 14-17 used an updated front suspension knuckle (aluminum) with a wider clevis opening - the bracket where the knuckle & strut are bolted together.
