Hello all.
I have thinkdiag obd for scan and now I want to buy another scan tool which have IMMO, TPMS and remove the dash light even without change or fix the problem ( engine or airbag...)
Which scan work well?
Thank you.
Best scan tool !!
Re: Best scan tool !!
I bought an Autel MX808 Maxi Check 3-4 years ago and have been pleased. It will read all of the modules on the 11-13’s. It shows a ton of data compared to the Actron CP9185 that I had been using. The Autel is around $400. Well worth the invest if you do most of your own repairs.
