Couple questions about White's BCM programming
For those that have had it done or know about it:
What is the end to end process? All I got from emailing the website was "You order this from us and after receipt it needs a setup run with a dealer scan tool (or other high end scan tool). It's not bad!" So is it a CD or some kind of code or what exactly do I end up doing? Am I reading in the forums correctly I need to send in my stereo?
Does this BCM programming affect my still current GM warranty?
And have you guys done the remote ignition start? On the website it says "may require new hood switch or other minor wiring changes as well as possible recalibration of the RFA/RCDLR and Immobilizer depending on how your vehicle was built". I'm also reading it sounds like given that I have a 9C3 there's a good chance it's ready for that +BTV option? And also, my key fob only has 4 buttons, Lock, Unlock, Trunk and on the backside, Red Alarm Horn button. I seem to remember seeing a different key fob that had a special button on it that was used for remote start. Would I need to get a new key fob?
Re: Couple questions about White's BCM programming
You will need a new button pad for the key fob, it splits the trunk button into two buttons, one of which is remote start.
The hood latch for remote start has a wire connector coming out of it, and it plugs into a connector near the radiator support.
You'll need to take it to a dealer to relearn the brake pedal sensor, something for the key, and the rcdlr for remote start.
Unfortunately I haven't gotten the rcdlr reprogrammed because my local dealer is staffed by turnips in polo shirts
Thanks indianajoe, that all sounds like good news. But do I need to send them my radio?indianajoe wrote:You will need a new button pad for the key fob, it splits the trunk button into two buttons, one of which is remote start.
And really it's that simple with the key fob? Mine has just the 3 buttons on the front, unlock, lock, and trunk. Does the trunk button on mine have two solenoids under it and the new button cover just has the split button like this one pictured, and just needs to be reprogrammed?indianajoe wrote:You will need a new button pad for the key fob, it splits the trunk button into two buttons, one of which is remote start.
- caprice_key_fob.jpeg (48.14 KiB) Viewed 19128 times
- 4_button_key_fob_pad.jpg (286.46 KiB) Viewed 19128 times
Remote Start for PPV's without it (from March 2013)
http://newcaprice.com/forum/viewtopic.php?f=21&t=30" onclick="window.open(this.href);return false;
Bottom line, you have to buy the transmitter, and swap your key over to it. There is programming still to be done to make the new transmitter & remote start functional, as well as the new hood latch, in addition to the BCM "patch" from WAMS.
The connector for the hood latch microswitch is at the top of the radiator support, directly behind the existing latch--purple in color.
In Parts Group 10.485
Transmitter complete with cover, 4 button/remote start
http://www.gmpartsdirect.com/oe-gm/92237316" onclick="window.open(this.href);return false;
Pushbutton molded rubber cover, 4 button/remote start (PART IN YOUR PHOTO)
http://www.gmpartsdirect.com/oe-gm/92245050" onclick="window.open(this.href);return false;
Latch (with RPO BTV remote start)
http://www.gmpartsdirect.com/oe-gm/92258586" onclick="window.open(this.href);return false;
You will have to learn the new transmitter to the car and/or pair it with a second transmitter. That relearn is in the owners manual. You get into the info center screen in the Instrument cluster via the steering wheel control. After you get the BCM reprogrammed and installed back into the car, you will have an ABS fault, Airbag fault and Traction Control fault. The Brake Pedal Position re-learn done by the dealer should take care of them. The dealer will also have to do the RCDL and maybe add the +BTV. IT depends a lot on the dealership. Some dealerships have balked at doing the +BTV as it is considered a deviation away from the original programming. I would get confirmation from your dealer that they will do it. Also make sure that they understand how to do it.
Regards,
Regards,
Thanks Bill, I read that whole forum and now am almost 100% educated on the matter. I'm still confused on 1 thing though, what do I need to send to Chris (besides the $175 frog skins)?Navy Lifer wrote:Remote Start for PPV's without it (from March 2013)
Thanks Maurice!Pursuit wrote:You will have to learn the new transmitter to the car and/or pair it with a second transmitter. That relearn is in the owners manual. You get into the info center screen in the Instrument cluster via the steering wheel control. After you get the BCM reprogrammed and installed back into the car, you will have an ABS fault, Airbag fault and Traction Control fault. The Brake Pedal Position re-learn done by the dealer should take care of them. The dealer will also have to do the RCDL and maybe add the +BTV. IT depends a lot on the dealership. Some dealerships have balked at doing the +BTV as it is considered a deviation away from the original programming. I would get confirmation from your dealer that they will do it. Also make sure that they understand how to do it.
I recall what I did was buy a new "blank" BCM, which I had the local dealer super-tech clone to match my VIN, and all of it's programming features, to keep all existing functions it originally had, then sent that to Chris for modification.v8suprcapric wrote:Thanks Bill, I read that whole forum and now am almost 100% educated on the matter. I'm still confused on 1 thing though, what do I need to send to Chris (besides the $175 frog skins)?
That allowed me to keep the car running until his work was done, then my tech swapped the BCM's and did the re-learns and anything else necessary to make remote start work. I still have my original BCM, un-modified, on the shelf.
Chris may remember differently....
Ok final question, where is the bcm located and does anyone have a picture of it? I shall have remote start this winter!Navy Lifer wrote:I recall what I did was buy a new "blank" BCM, which I had the local dealer super-tech clone to match my VIN, and all of it's programming features, to keep all existing functions it originally had, then sent that to Chris for modification.v8suprcapric wrote:Thanks Bill, I read that whole forum and now am almost 100% educated on the matter. I'm still confused on 1 thing though, what do I need to send to Chris (besides the $175 frog skins)?
