Power Window issue
Power Window issue
I have been having an intermittent problem with my power windows. About a month ago the driver's door window stopped working and was stuck in the up position. I can hear a relay clicking when I hit the switch. I assumed that since all the other windows worked that it was the motor so I ordered a new one. Two days later the window started to work briefly but then got stuck in the down position. That night I got into the door to try to get the window to stay in the up position, in doing so the window came back to life and has worked ever since until today. Today the driver's window stopped working again for about a 1/2 hr. and then started to work again but now neither rear window will work. Is there a dedicated module for the power windows?
Mike
Mike
Re: Power Window issue
Some have wires separating inside the insulation causing an intermittent connection. Check inside or near the boot at the door hinge area. (Where it bends and pulls every time the door opens and closes)
Lightly tug on each of the wires- if one feels "stretchy" it's broke inside the insulation.
2011 9C1 6.0
Flex fuel tune
Flex fuel tune
smwalker wrote:What year you got ?
2012
i will give that a try, i had a that happen on a Ford Explorer once..... drove me crazyjackleg wrote:Some have wires separating inside the insulation causing an intermittent connection. Check inside or near the boot at the door hinge area. (Where it bends and pulls every time the door opens and closes)
SO there is what is called a "logic module" on the 11-13's But all that seems to be responsible for is the "Auto Down" feature on the two front windows. I ran across it before it is mounted high on the passenger side kick panel pretty much in the dash. I would investigate the frayed wires, that seems more likely to me.
Found the problem, puzzled as to how this would happen, the car is still fairly young (2012) 69,000 miles anyone else come across this ????
- IMG_20170422_183140606.jpg (4.08 MiB) Viewed 16739 times
- IMG_20170422_183159193.jpg (4 MiB) Viewed 16739 times
Those seem like some clean cuts. Any damage to the rubber boot?
Resized:
Resized:
smwalker wrote:Those seem like some clean cuts. Any damage to the rubber boot?
the boot is fine, all i can think of is that something went wrong during assembly at the factory
Resized:
would you believe the same problem has comeback !!! would anybody have the part # for the drivers door harness ?
