Need to replace the rear trim on the trunk lid
When prepping for yesterday's autocross event, we discovered that the right side of the chrome strip on the trunk lid had popped away from the sheetmetal. On further examination, it appears that the slot for the mounting stud has broken away from the trim piece, so we'll need to replace that strip. I recently treated the car to a hand wash and wax job from a local mobile detailer, who may have broken that piece, but given the car's history, can't point the finger definitely at them, so time to break out the card.
Two questions:
1. Has anyone replace that strip yet, and have any pointers? I have the FSM, so will be digging through that before starting, and,
2. I'm trying to figure out what 'Rad Grl' means on this anchor piece:
http://www.gmpartscenter.net/chevrolet/ ... lding-clip
I can't come up with anything repeatable for what that means. Thoughts?
Two questions:
Re: Need to replace the rear trim on the trunk lid
the part is used on alot of cars , and one is for the radiator grill aka rad grl
I replaced mine with an Aussie embossed one, not a hard install at all, and i had to modifymy aus one to remove a center mounting post because of the keyhole
It's simple to remove. Remove the two nuts on the ends and don't lose the rubber washers under the nuts. The rest of the trim is held with the anchors which engage the holes in the sheetmetal. I found the right metric socket size and just reached inside the trunk sheetmetal with it. If you put the open end over the tail of the anchor and push in, the socket will push the anchor "lip" in and disengage it. Don't try to pry it from the outside unless you don't care to break the plastic anchors.
I don't have a picture of the anchors but this picture shows the holes in the trunk.
2014 Chevrolet Caprice PPV
2014 Chevrolet Stingray Z51
2016 AMG C63
2015 BMW X5 iDrive 50i
2016 AMG C63
Gene if me memory is serving me I think Karo has some "CAPRICE" embossed ones in stock.
What did you do with the keyhole? Just leave it under the molding strip?indianajoe wrote:I replaced mine with an Aussie embossed one, not a hard install at all, and i had to modifymy aus one to remove a center mounting post because of the keyhole
he does have themsmwalker wrote:Gene if me memory is serving me I think Karo has some "CAPRICE" embossed ones in stock.
I have caprice and statesmen in stock. i'll see if i can get some pictures posted
Thanks,
Karo (Just like a car, but add an O at the end of it... Car-O)
Karo, I'd like to see these. Thank you.
But it listed on the page for the trunk lid trim. That's a little far from the radiator!!s/c'd cav wrote:the part is used on alot of cars , and one is for the radiator grill aka rad grl
