Kerr/Soundoff Signal Module - Stock Wigwag Issue [Solved]
Re: Kerr Equipment - Wigwag Module
So I've received the Soundoff module, and it plugs in line under the hood. I am planning to drop the glovebox shortly and take some pictures for you. Reading some info about the police wiring, do I need this GM (95710161) connector at all? Or would it benefit me? I have the empty connector mounted to the top of the trunk as well.
Active Duty USAF
Active Duty USAF
What you find behind the glove box will determine inf you need that part. You would only need it if they completely removed he upfitter harness from the car. Most times they just cut it to disconnect things and leave the harness in tact.
Thanks again man!smwalker wrote:What you find behind the glove box will determine inf you need that part. You would only need it if they completely removed he upfitter harness from the car. Most times they just cut it to disconnect things and leave the harness in tact.
Active Duty USAF
Active Duty USAF
Okay so I have her all ripped open and I found the red and green wire. The module is wired into the headlamp under the hood. There are two black wires next to the red/green, testing them both with the red/green doesn't give voltage. When I take one of the black wires and connect it to the kick panel ground the car horn starts going off, and when I test the red/green with that black wire it gives me negative voltage. A friend is supposed to be picking me up a 12v switch. What do I need to do? I put a big ring terminal on that black ground next to the capped off red and white thinking maybe it needs to be grounded.
Eagerly awaiting your reply.
- IMG_20171001_131645.jpg (477.04 KiB) Viewed 17511 times
- IMG_20171001_131312.jpg (347.18 KiB) Viewed 17511 times
- IMG_20171001_131246.jpg (664.24 KiB) Viewed 17511 times
Active Duty USAF
Active Duty USAF
So the green wire with the red stripe. Apply 12 volts to that wire and wig's should be waggin.
The two black wires I suspect are your horn bypass and they hooked them together so the horn would work again. If you follow those down to the firewall I bet you will see them connected at the firewall under the blower motor.
smwalker wrote:So the green wire with the red stripe. Apply 12 volts to that wire and wig's should be waggin.
Okay, unfortunately applying 12v to the red/green doesn't make them turn on. I tried with an unplugged connection and a spare battery. Do I need to connect any other wires or that orange one? I'm pretty much done with the project for the day. Do I just need a 12v switch?
And are the flashers already grounded out or does that need to be done? Do you think those two thick grey Kerr wires have anything to do with this?
Active Duty USAF
Active Duty USAF
Did you have the car on when you tied 12 volts to the green/red wire?
Can you post a pic of how you have the wig wag module hooked up to the headlamp harness.
smwalker wrote:Did you have the car on when you tied 12 volts to the green/red wire?
I think I have it hooked up normally, and tried multiple 12v sources. They never turned on.
- IMG_20171001_182632_01.jpg (622.83 KiB) Viewed 17505 times
Active Duty USAF
Active Duty USAF
Huh, yea that looks good, let me go home and look at mine. Will report back.
Thanks!smwalker wrote:Huh, yea that looks good, let me go home and look at mine. Will report back.
Active Duty USAF
Active Duty USAF
