LSA Supercharger Installation
Re: LSA Supercharger Installation
7) INTAKE
For the intake, I intended to weld up a custom 4” aluminum unit. However the Friday afternoon before the Christmas holiday, I realized I was almost out of Argon shield gas and everything had already closed…AAARRGH.
I had a leftover New Era CAI from my old CTS-V wagon. I did a couple of test fits and the MAF and PCV port was in the perfect location. The filter also fell perfectly into the dead space where the old airbox resided. Looked like a plan!
The only minor issue was that the CTS-V uses a different MAF style than the LS7 card MAF I intended to use. Luckily in my box of 4” mandrel bent aluminum tubes was an LS7 Card MAF plate. It looked like I could machine that down to make an adapter plate.
I drilled and counterbored the aluminum adapter plate for some small M5 stainless cap screws. On the intake itself, I cut off the mount bosses for the old CTS-V MAF then match drilled and tapped mount holes. I also had to remove some material to accommodate the LS7 MAF width. I sprayed some engine enamel on the areas I ground down and installed the new interface plate with black sensor safe RTV.
Here’s the finished result of the MAF adapter.
Now installed in place with the IAT breakout cable
The PCV connector needs to be rotated to connect properly to the intake. It required the use of a heat gun. It is on there really tight.
Hood closed and picture taken looking forward to check hood clearance; there’s plenty.
Intake looks pretty good (but I’m a little biased).
2014 Chevrolet Caprice PPV
2014 Chevrolet Stingray Z51
2016 AMG C63
2015 BMW X5 iDrive 50i
2016 AMG C63
Nice, detailed write-up, and nice work. Looks like it is NOT a plug and play sort of project.
Thank you 'Crash. None of these projects are ever plug and play are they? ....but I'm fine with that. LOL.CrashTestDummy wrote:Nice, detailed write-up, and nice work. Looks like it is NOT a plug and play sort of project.
2016 AMG C63
2016 AMG C63
I second the sentiment! Great documentation, explanation and pictures. I appreciate the attention to details. Great effort and job!
Regards,
Regards,
Thanks for the great read Silver, always interested to follow your exploits.
Still getting up the guts to semi-mimic your center console work.
Steve Robin
Minneapolis, MN
Minneapolis, MN
Thanks Maurice. I know a lot of fellow owners want to install an LSA blower so I thought my experience may be useful to some.Pursuit wrote:I second the sentiment! Great documentation, explanation and pictures. I appreciate the attention to details. Great effort and job!
Regards,
2016 AMG C63
2016 AMG C63
Thanks SBRMD. Just jump in!!! LOL.SBRMD wrote:Thanks for the great read Silver, always interested to follow your exploits.
Wait until you see my mod of the complete new return style fuel system with dual staged fuel pumps......but that is another discussion.
2016 AMG C63
2016 AMG C63
8) Heat Exchanger
This is a topic I spent too many hours of head scratching on trying to decide,
1) How to keep the windshield washer tank?
2) How I can keep as much of the trans cooler unblocked ?
3) Do I move the trans cooler?
4) Do I just buy a ZL1 AFCO unit and take out the Sawzall? (again with the Sawzall),
5) Do I buy an HX core and weld up my own HX?
6) etc. etc. etc.
While I’m still going to eventually weld up my own HX or modify an ZL1 AFCO unit, for now I decided on the Edlebrock 15409 which have the following dimensions, 17”(W) x 11”(H) x 2”(D). It fit nicely and allows me to retain the plastic scoop in the bumper and provide a more factory look, if that can be achieved.
I did loose the the washer reservoir. I got over it. LOL. That will be a project for another day (got some great ideas here…stay tuned).
As mentioned, I did not have any Argon over the Christmas holidays so I used an old fab hack that has worked in a pinch for me. JB Weld and rivets! Luckily I only had two lap joints in the whole bracket setup.
The Edlebrock already had 2 bosses on each side tapped for 6mm bolts. The entire bracket system comprised of two 2”x2”x0.125”T aluminum angle brackets and two small lengths of 0.125” thick bar stock. The mill made short work of the brackets and slotting of mounting holes. The brackets pick up the four threaded bosses on the back side of the crash bar that normally hold the washer fluid canister. I was prepared to add a third bracket on top but it didn’t need it since the installation is incredibly sturdy with just the brackets.
Here is the result.
I used the Cobalt filler neck for now and mounted it off a solid tab coming off the fuse box. I machined a bracket that indexes on the sides of the fusebox so the filler neck is locked into an angled orientation to facilitate the hose routing .
The -12AN braided hoses were run from the lid assembly down to the filler neck and to the pump. Since the details count, I secured the hoses with proper -12AN billet separators and finished the hoses at the filler neck with termination clamps.
The HX bottom outlet goes straight outboard through the 1.25” DIA hole and turns 90degrees to the pump inlet. This is one of the pieces I had to hunt for at AutoZone. I just found any 3/4” heater hose and cut it to size.
The only thing I have to say about the wiring of the pump is tap into the fuel pump controller. I would rather tap into a less critical system like the body controller fuse above it but my fuse tap interfered with another fuse.
6) etc. etc. etc.
Here is the result.
2016 AMG C63
2016 AMG C63
So when is your PNP LSA kit for the ‘11-‘17 Caprice going to be available for order?!? I bet you can sell tens!!
Put me down for one.
Seriously, though, you are doing stellar work, especially in the fabrication department.
CrashTestDummy wrote:So when is your PNP LSA kit for the ‘11-‘17 Caprice going to be available for order?!? I bet you can sell tens!!
Thanks Gene. LOL. I have no intention of selling kits for this. That’s why I’m spilling the beans on the details of my build; kinda an open source thing. It’s just one interpretation of how an LSA install goes together. I hate sketchy workmanship so although I could have banged it together in 2 days I decided to take my time over the Christmas break.
2016 AMG C63
2016 AMG C63
