Page 1 of 2
Oil pressure sensor range / oil pressure sensor
Posted: Sun Jan 21, 2018 9:09 pm
by Can't Wait
My check engine light came on and it was the oil pressure sensor, I change it and after about 3 months maybe it came back on and sometimes go off and comes back on wha t could be cause this to come back and off help thanks in advance
Re: Oil pressure sensor range / oil pressure sensor
Posted: Sun Jan 21, 2018 10:56 pm
If I recall correctly, and i might not. Right under the pressure sender in the hole is a little puck with a screen on it that some of the G8 guys had issues with. Might want to dig that out and tale a look at it.
Hope that helps.
Posted: Mon Jan 22, 2018 7:51 am
by lastcall190
Sorry for hijack, but I was actually just going to post and rather have two threads back to back on the same thing, figured I'd add my experience.
Timely thread, I have been chasing a P0521 code since I changed my oil the first time with a PF48E filter (I saw the TSB on a search here, and the temps were single digits and teens around that time). Changed out filter for the UPF48R, went away. Came back on a drive to tune the car, tuned the car, went away. Ran a few errands, nothing. Drove yesterday to the store, came back on the way home from the store, and that was with a new sensor and new screen (stock was almost spotless after 94k miles). I have an OP test plug arriving today and a mechanical gauge I am going to hook up to check the pressure. Pending the pressure checks out, my only guess would be a bad sensor out of the box? Quite annoying as I want to just get the damn car inspected and there seems to be no pattern for the code coming and going.
Posted: Mon Jan 22, 2018 8:02 am
by Can't Wait
Thanks guys I will look in to both I just know I put a sensor on and it's strange to me that it would happen, didn't know if I was alone on this one
Posted: Mon Jan 22, 2018 8:33 am
by indianajoe
Are you guys using oem sensors? That's what did the trick for me
Posted: Mon Jan 22, 2018 8:37 am
by lastcall190
Fresh OEM sensor and lifter filter. I saw a thread on the G8 board where someone unplugged batteries overnight and it fixed the code and never came back... I can't imagine why it would but I'm sure someone way smarter could explain to me why. After I did that, the car fired right up, idled a while, no light. Would've taken to work today to check it out on a long drive, but one of my headlights decided to burn out overnight
I've also seen guys change sensor, no change, but then change the oil and filter, and light never comes back. I'm interested to see what my mech gauge comes back with.
Posted: Mon Jan 22, 2018 10:13 am
Don't these engines also have a known issue where the o-ring for the oil pump pickup slips, or something like that? Might be something else to look at if the oil pressure really is dropping.
Posted: Mon Jan 22, 2018 11:32 am
by Can't Wait
Need to buy an oem sensor and see wha t happens, I will keep y'all inform
Posted: Thu Feb 15, 2018 4:55 am
by lastcall190
Any updates? I've been chasing mine for weeks, and monitoring pressure on the Torque App. I can clear it, drive around a few times, then it comes back and my entire operating range of oil PSI seems to just scale down the moment the light trips.
Let us know.
Posted: Thu Feb 15, 2018 10:46 pm
by Mooseman
On my other vehicle (2006 Saab 9-7x 5.3L, aka: Trailblazer), when I deleted the DOD, I replaced the oil pump with a regular LS pump. When the oil was below 50% life left, P0521 code came up. Replaced the sensor (no screen anymore), same. After some research, finally determined that I used the wrong oil pump. Should have been a high pressure and volume pump for DOD. Even though DOD hardware is all gone, the bypass in the pan is still there and probably still affects pressure. I never bothered with it, still comes on and after an oil change, goes away on its own. I believe this code is specific for DOD systems so that there is adequate oil pressure for it.
