2014 Caprice Check engine light/Service power steering/stabi
Had this happen twice, once when I bought the car, the service power steering warning came up on the display, the engine rpm and speedometer stopped working, check engine light on, service stabilitrak etc. I believe the scan tool showed that the car had lost communication with various modules. After clearing the code, I drove the car on and off since last august, today I had the same thing happen, but additionally the car seemed to go into limp mode, slowly getting up to speed and not shifting. I dont know if its a loose ground wire or what, wondering if anyone has had similar issues. (I believe the rack was replaced at some point)
Re: 2014 Caprice Check engine light/Service power steering/s
Have you had the steering rack replaced in the recall?
I’m pretty sure it was replaced already a buddy of mine looked it up through the GM history, I’ll ave to double check
Low battery.
Buy a smart charger and charge the battery.
Black 2014 V8
Did you have that problem, I have a dual battery car, and I was driving the car for an hour so I can’t see it being the battery unless there’s a big draw I don’t know about
Or a failing battery. Get it load-checked.
Car isn’t capable of fully charging the battery. Good job GM. Have to use a charger to do that. I’ve had a few of these caprices and like other gm cars when a battery or alternator is low it screws up lots of things. That’s where I’d start.AKB360 wrote:Did you have that problem, I have a dual battery car, and I was driving the car for an hour so I can’t see it being the battery unless there’s a big draw I don’t know about
Black 2014 V8
If you really have a 2014, then you have electric steering.
Re: 2014 Caprice Check engine light/Service power steering/stabi
Any fix to your issue OP?
