check engine light high voltage from oil pressure switch?
jj55chevy
Post by jj55chevy » Mon Dec 24, 2018 9:57 pm
is anyone familiar with this condition? I just bought my 2012 Caprice PPV a week ago and the check engine light came one. I took it to O'riely's and they scanned it, came up as high voltage from the oil pressure sensor. Should I roll the dice and buy a $70 switch and hope that is the problem or are these cars known for some other ailment that would cause this? any help would be greatly appreciated!!
jj55chevy
Re: check engine light high voltage from oil pressure switch?
Post by jj55chevy » Sat Jan 26, 2019 12:48 am
just an update: it was the oil pressure sending unit...$70 later and it's all good!
Post by Mooseman » Sun Jan 27, 2019 9:51 pm
Good to know. 90% of the time, it's a fault with the sending unit.
jj55chevy
Post by jj55chevy » Sun Jan 27, 2019 10:28 pm
I just wanted to hear that before I bought one...thanks
SS396ELKY
Post by SS396ELKY » Thu Feb 07, 2019 2:46 am
I had this exact code this morning P0523..
What brand switch did you buy..?
And where is the switch located...?
jj55chevy
Post by jj55chevy » Sat Feb 09, 2019 12:11 am
I'm not sure what brand it was, I bought it at Orielys for about $74. it is located at the back of the engine on top just like the old small lock chevy oil pressure switches. it's actually not too hard to replace. they reset the code at orielys and I have had no problems since.
119C3NJ
Post by 119C3NJ » Sat Feb 09, 2019 3:18 am
Buy AC Delco off Amazon, very close to chevy employee price! Grab a new screen while your at it. Deep socket short extension easy peasy
1995 MG5 Yukon GT Black
SS396ELKY
Post by SS396ELKY » Mon Feb 11, 2019 12:28 am
Well I changed out the sensor and it fixed the P0523 code problem... What a pain in the ass to change out this sensor and filter... It looks as though the sensor was seeping up through the electrical pins...
jj55chevy
Post by jj55chevy » Wed Feb 13, 2019 12:25 am
yikes!! mine wasn't that bad...but you gotta admit, it's a cheap cure!
camrat68
Post by camrat68 » Wed Feb 13, 2019 6:09 pm
Does anybody have a part number-either GM or parts store-for the sensor and screen? I tried finding it on GMPartsDirect with no luck.
Thanks,
Jim
Jim Chesnutt
1968 Camaro -my first car.
1995 Black/White 9C1 Caprice
