Just installed 2019 Camaro 18 rims TPS issues?
Was fortunate to get 4 wheels and 4 tires with 500 miles off a 1lt Camaro but now my TPS light are on
I guess the sensors are diff what is the best and least expensive fix
- 6DB9557B-FA69-487B-A35A-659F21E933B2.jpeg (4.57 MiB) Viewed 16725 times
- 29C3178F-0530-43CC-B7F4-6A4DD122D55C.jpeg (5.79 MiB) Viewed 16725 times
Re: Just installed 2019 Camaro 18 rims TPS issues?
Try doing a sensor relearn?
Are the sensors the Same ?
Off hand, I don't know but since they're already in there, might as well try doing the relearn.
what year is your ppv ? I found I can t do the relearn on my 2016 like you can on the older ones even though I can get the re learn screen to show on the car. ???
You could also try a tire shop and have them re learn it with the scan tool, that s quick.
I also tried to buy an auto zone scan tool for myself but again, not going to work with one of those on the newer PPV s.
2016 C1
On my 14 it says to use a scan tool. I just bought a cheap $12 one on amazon. Worked great.cerbomark wrote: ↑Sun Apr 07, 2019 7:50 am what year is your ppv ? I found I can t do the relearn on my 2016 like you can on the older ones even though I can get the re learn screen to show on the car. ???
Kinda strange ?
Drove car 60 miles on highway
Lights came off all by themselves ?
I did a TPS relearn on the dash last night but
Miraculously it was fixed this morning by itself
Does it show actual pressure readings?
On my '11, the cheap Amazon tool worked for me too but it should work with letting air out.
Yes it does !
FYI
The TPMS sensors on late model Chevy are a different frequency 415mgz opposed to 315 that comes in the PPV not comparable I had to take the old ones off the steel wheels it worked for a whole day then lights on ?
