OFFICIAL Master Production List - All Years
Ben98gs
Post by Ben98gs »
I am a number guy and got a little bored, so I decided to compile a spreadsheet with all of the VIN/production info that I could find for the SS Sedans. You can find the information/topic here: SS OFFICIAL Master Production List - All Years
I recently decided to build off of that data and start a second sheet for the Caprice PPVs. I am working to compile a list of as many VIN numbers as I can readily determine (based upon VINs I find online and building sequentially off of those, excluding ones I know are for the SS cars).
You can view the document here (will update this with the shared file/link once I get to my home computer, work blocks Google Drive): Caprice OFFICAL Full Production Specs List Spreadsheet *Best if viewed on a computer*
Cycle through the tabs at the bottom to get to the specific production list for each year. The tabs might be at the top on certain mobile devices.
Hopefully you find this as helpful and informative!
I hope that eventually I might be able to find "all" the Caprice VINs (as close as possible to the assumed total sale numbers) and the cumulative list will show the full production specs. Eventually I hope to possibly pull RPO code information to update the file to indicate corresponding paint color and possibly other "desirable" options.
For now, I could use your help with the collection/processing of information. If you could you provide the following information that you have on any 2011-2017 Caprices:
NOTE: Since some people may be sensitive about providing full VIN, you may provide only the last 6 of VIN for security purposes (even with last 6 digits you would still need to recreate/determine the check digit to know the full VIN)
Model Year:
VIN (last 6 digits is fine):
Color:
Engine:
Other "unique" information (9C1/9C3 for applicable years)?:
2016 Chevrolet SS Sedan - Slipstream Blue / M6 / Sunroof / Spare - 1 of 69 as optioned
Caprice OFFICIAL Master Production List
Ben98gs
Re: OFFICIAL Master Production List - All Years
Post by Ben98gs »
Here is an example of the current sheet setup for some of the 2017 VINs I have identified (again, this will be linked in original post once I have access to Google Drive):
Ben98gs
Post by Ben98gs »
For now, here is the link... Hopefully I can get it added to the original post.
Caprice Official Master Production List
bjarvis28
Post by bjarvis28 »
I won't be too much help, you already have my vin listed through NY open data.. I was lucky enough to find 6g1mk5u25cl602184 at a New York State surplus auction on 4/17/19. Its a 2012 Black 9c3 6.0 optioned car, built 10/2011. I highly suspect it was used in the NYS Bureau of Criminal Investigation Unit (BCI). All regular troop cars are blue and I know of a BCI investigator that was assigned an unmarked caprice for duty which leads me to believe they probably did a run of these cars for BCI.
SSpeedracer
Post by SSpeedracer »
2016
219793
Mystic Green
L77 6.0
2016 Caprice
Neumeier83
Post by Neumeier83 »
975006
2014
Black
6.0
City of Durango Colorado
Purchased from Chicago Motors
Oldblue68chevy
Post by Oldblue68chevy »
2011
524729
White
6.0
9c3
2011 PPV 9C3
Ben98gs
Post by Ben98gs »
Thank you! Got them in the file.
lastcall190
Post by lastcall190 »
2012
6.0
9C1
643522
Black
Ben98gs
Post by Ben98gs »
I still hope to work on this VIN project, but for the time being here is information that I received from a GM certification engineer at Holden that worked on the PPV export project.
