Looking for 2014+ shifter wiring diagram
Re: Looking for 2014+ shifter wiring diagram
I still need to hook up the bulb for the gear indicator on the shifter to the lights.
In the Caprice that circuit is called LED backlight control. On a 2014 I would imagine the closest place you could tap into it would be the back of the HVAC controls. Looks to be a white and yellow wire at the HVAC panel plug spot 9 :
Is there a storage bin in the Camaro COnsole?? It have a light in it?
Ilikemtb999
Post by Ilikemtb999 »
Looks like I never snapped a picture of the entire thing. I’ll do that in the morning. It does have a storage bin and two cup holders. No light but it’s got a 12v plug outlet and a usb which I need to buy an extension for. Still unsure on the parking brake, the camaro one is ugly and on the passenger side which seems odd. I think I could trim the stock plate for the foot pedal and fit it under there.
Also thank you for finding that. Wiring the accessories up will be next.
lastcall190
Post by lastcall190 »
FWIW the 04+ GTO had the ebrake on the passenger side as well. Was weird at first but you use it only a handful of times per trip and forget about it. IMO I would just do that, especially if it matches the console. Nice install so far thanks for the pics.
Ilikemtb999
It sure looks like it would just bolt in and hook up to the e brake cable. It looks like such an afterthought but maybe I’d get over it. (Too bad there isn’t enough room for the aux gauges in front of the shifter)
lastcall190
Funny, before I even read your comment I looked at the pic and thought... "GAUGES..."
I agree the Camaro e-brake does kind of look like an afterthought. Damn, at least they could have maybe used a pleather boot or something :lol:
Ilikemtb999
If only there was enough room in the cubby area but they’d be buried in the dash.
I’ll have to decide on the E brake. The foot one is fine but I removed the plate to fit the console. I’m sure it could be trimmed down and still function but then that leaves the console a bit unfinished looking.
Lscaprice
Post by Lscaprice »
Need help with mine I have the ss paddle shifter and also trying to throw on the ss floor shifter what shifting cable did u guys use ?
Also when I wire the the steering wheel what pin does it go connected to in the bcm? Do I also have to runs pin to the tcm or ecm ?
Lscaprice wrote: Tue Feb 07, 2023 10:26 pm Need help with mine I have the ss paddle shifter and also trying to throw on the ss floor shifter
You can combine the wires from the shifter and the paddles into one spot on the BCM. Only thing you will need to do is have an ON/OFF switch somewhere on the wire going to the paddles.
No, no wires to the TCM or ECM. Only BCM
Then just have to turn on the TU/TD in the TCM using HP Tuners or similar.
See this post for Diagrams and pinouts: viewtopic.php?f=21&t=4321#p31923
Capeasy
Post by Capeasy »
Is the wiring diagram different for a 2013 Steve?
Walt (AKA:Capeasy) So. Cal.
Capeasy wrote: Fri Nov 24, 2023 3:44 pm Is the wiring diagram different for a 2013 Steve?
Yea everything different from WM to WN.
