What year did the New LED spot lights start appearing on our PPV? I would love to get a hold of a D/S for my 2013-9C1.
Walt
LED Spot lights ?
LED Spot lights ?
Walt (AKA:Capeasy) So. Cal.
Re: LED Spot lights ?
I would expect that the bulb is replaceable, so if you find an incandescent light assembly, you can swap out the bulb for a LED module. The later units come with plastic 'bulbs'. The one in our Tahoe PPV was plastic, and the Florida sun hazed the lens so bad, it looked like it had been painted a tan color of dullcoat. I found a glass replacement and now have a nice spot light, should we ever need it.
If you find the P/N for the LED light, please share it, I might replace the bulbs on our 3 retired service vehicles with them.
EDIT: Perhaps this will work?
https://www.unityusa.com/U-8547-6dia-LE ... _1789.html
That's just the bulb, though. Not cheap!
EDIT2: Here's the whole bulb:
https://www.fleetsafety.com/soundoff-es ... ht-insert/
mine even out of the sun has yellowed , and i couldnt get it replaced under warranty again , idiot tech was claiming it was rock damage
That's why I went with the glass bulb on the Tahoe. No more yellowing, and you KNOW when there's rock damage.
yeah thats the one downside to glass
all the LED units ive seen hold up alot better , i dont think ive seen a yellow one yet
I have one of those dual LED spots, red and white (Fire dept usage) I tried to upload a video, but the site won't except it. Pretty cool light, the regular is wicked bright. I paid way to much, but it was worth it.
2014 Caprice PPV silver
2017 Ram 3500
2002 CETA trans am
1995 9c1
1977 Trans am SE 4spd.
1978 trans am 400 4 spd.
2017 Ram 3500
2002 CETA trans am
1995 9c1
Does anybody have a loose -out of the spotlight- bulb to take the measurement on the outside diameter of the bulb?
Thanks,
Jim
Thanks,
Jim
Jim Chesnutt
1968 Camaro -my first car.
1995 Black/White 9C1 Caprice
Mine was all yellow and nasty.
I ordered this off Amazon:
H5001 LED Flood Par46 LED Lights, Round LED Headlights Fit for Unity Spotlight 5.75" 5-3/4" Truck Led Work Lights Replacement Sealed Beam Projector 36W Chrome Truck Offroad https://www.amazon.com/dp/B072HSLXYC/re ... tDbHYV1GRR
Not only did it fit perfectly, but man is that thing bright!!!
- 20190809_175604.jpg (4.83 MiB) Viewed 16458 times
+1 on the 36 dollar Amazon light. Got that on my squad.
Brighter than 100w halogen and fits perfect. Only minor grinding on positive tab to fit the spade connector perfectly. Great upgrade.
Active Duty USAF
Active Duty USAF
