3:27 Chevy SS Diff' vs. 3:45 Camaro
kevink
Re: 3:27 Chevy SS Diff' vs. 3:45 Camaro
Post by kevink »
An easy way to remember what's important is that the 2010-2015 Camaro LSDs are the only ones worth installing.
SSpeedracer
Post by SSpeedracer »
Where are you guys finding the best deal for 3.27's? On line, ebay, craigs list etc? Or local salvage yards?
2016 Caprice
Yes! :D
I got mine from a seller on one of the G8 forums. So there's those, too. And don't forget the Chevy SS forum, since some may go bigger and want to get rid of the factory diff.
VintageIron41
Post by VintageIron41 »
Pardon, if I didn't clarify, I meant the entire rear end suspension, including differential and axles. the complete assembly. I doubt the SS and PPV interchange, but one source is telling me yes they do.
VintageIron41 wrote: Wed Jan 08, 2020 11:15 am Pardon, if I didn't clarify, I meant the entire rear end suspension, including differential and axles. the complete assembly. I doubt the SS and PPV interchange, but one source is telling me yes they do.
YES , the whole cradle will swap over , same with the 5th gen camaro
youll need to keep your shock/spring assembly , unless you get one from a 14
kevink
Post by kevink »
SSpeedracer wrote: Wed Jan 08, 2020 10:40 am Where are you guys finding the best deal for 3.27's? On line, ebay, craigs list etc? Or local salvage yards?
Also try Camaro5
VintageIron41
s/c'd cav wrote: Wed Jan 08, 2020 11:31 am
Thank you s/c'd cav, I have a lead on a 2014 Chevy SS complete rear end assembly with low miles, it's a 3.27 ratio, my thoughts are that since my PPV is also a 2014, and has 128k miles on it, that swapping out the entire assembly, IF it interchanged, would be practical to freshen the entire unit while gaining the gear change. So if both the SS and the PPV are of the same year, 2014, it is a one for one swap?
As always, thank you!
lastcall190
Post by lastcall190 »
http://newcaprice.com/forum/viewtopic.p ... d&start=30
That guy swapped one for one into a pre 2014 IIRC. Might be some useful information for you there, or even just PM him if need be.
VintageIron41
VintageIron41 wrote: Wed Jan 08, 2020 12:19 pm
Picture is unit mentioned in above post.
ChevySS 2014 rear axle assembly.jpg (111.22 KiB) Viewed 11045 times
yes direct swap , just need to get the car tuned to correct the gear change
youll want to check the sway bar size , and keep the larger one on the car
youll need to swap over the park brake cables , the SS is electric , where ours is mechanical
