Where do you find the pinout for the bcm plugs?s/c'd cav wrote: ↑Thu Sep 17, 2020 11:26 ami think that is for the button boxNate68c10 wrote: ↑Wed Sep 16, 2020 11:01 pmDoes anyone have a drawing of this with the ss steering wheel that has paddles?bearcatfan78 wrote: ↑Tue Mar 03, 2020 3:24 pm If anyone is interested, here is the schematic for the 14-17
https://imgur.com/jSch5de
the 14-17 caprice uses the same clock spring as the SS , so once the steering wheel is swapped , you need to add a wire from the body side of the clock spring to the bcm , then having he tune changed for the trans to accept the paddle shift
Paddle Shifter Write-Up
Re: Paddle Shifter Write-Up
2014 Caprice
Tsp LS3 stage 1 cam
3400 circle D converter
3.27 Camaro diff
Hoosier dr2 drag radials.
11.86 at 117mph
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
It’s on the first page in Dons post.Nate68c10 wrote: ↑Thu Sep 17, 2020 12:49 pmWhere do you find the pinout for the bcm plugs?s/c'd cav wrote: ↑Thu Sep 17, 2020 11:26 ami think that is for the button box
South Cackalacky
2014 Caprice PPV
2005 Pontiac GTO
1998 Lexus SC400
2014 Caprice PPV
2005 Pontiac GTO
1998 Lexus SC400
Are the bcms plugs the same from the two generations? If that plug is the same on my 14 I'm good to go I just dont want to cook anything.
2014 Caprice
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
Anyone? I really would like to dive into this so we can have a clear answer of what is needed. Is the wiring on the bcm the same as the 11-13's as it is on the 14-17's?
2014 Caprice
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
So what I'm gathering is the x3 plug on the 14-17 is the blue plug and I need to add a pin 11 to the blue plug and then run a wire to the clock spring connection 8 that is for the shifter on the ss wheel?bearcatfan78 wrote: ↑Tue Mar 03, 2020 3:24 pm If anyone is interested, here is the schematic for the 14-17
2014 Caprice
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
So I'm guessing wire from pin 11 in the blue connector to pin 8 in the clock spring and then turn on tap up and down in hp tuners? What activates the paddles?
- 20200921_084738.jpg (3.58 MiB) Viewed 9113 times
2014 Caprice
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
No ideas?
2014 Caprice
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
- thetonytolbert
Groundczero wrote: ↑Wed Feb 12, 2020 3:31 pm I think this is the same guy is claims he has a patent on this on FB.
But when you do a patent search on his name no patent comes up and he refuses to post the patent number.
http://patft.uspto.gov/netacgi/nph-Pars ... ing&d=PTXT
Still waiting for the patent information...hmmm
2015 Chevy Caprice - Heron White
Former South Dakota Highway Patrol Car
Full Holden Conversion
https://www.holley.com/garage/view/7279 ... t-caprice/
Thanks for all the awesome info. I just built and installed the shift box per the write up and it works great. I’d guess I have 8hrs invested including research and purchasing time.
I got my BCM pin from the junkyard out of a 2012 Cruze. My local dealer wanted $17 ea and I had to buy a pack of 5! That was the hardest part.
- D4BBCB65-0049-4191-AFED-32AA1B1F09F2.jpeg (3.98 MiB) Viewed 6001 times
- 48DC656F-B4A6-451C-B04B-AE83CAC7AB25.jpeg (3.91 MiB) Viewed 6001 times
- thetonytolbert
bumpc723 wrote: ↑Fri Aug 13, 2021 9:15 pm Thanks for all the awesome info. I just built and installed the shift box per the write up and it works great. I’d guess I have 8hrs invested including research and purchasing time.
Bravo, sir...absolutely bravo! This completely solidifies the claims made that this design doesn't work, when in fact it absolutely does. Kudos to you for the ingenuity and ambition to build one on your own. Love the design.
