Airaid 250-324 CAI
grittenhou
Airaid 250-324 CAI
Post by grittenhou »
Any on this forum running this CAI?
https://www.amazon.com/Airaid-250-324-P ... =1-2-spell
If so, thoughts/comments are appreciated. Thanks!
grittenhou@gmail.com
2014 Caprice 9C1 L77
2006 GTO 6M
2004 Sierra 2500HD
1978 Trans Am WS6
1974 Blazer K5 4M
1968 GTO 400HO 4M
1965 GTO 462 4M
Ilikemtb999
Re: Airaid 250-324 CAI
Post by Ilikemtb999 »
I have one on my car. It makes noise when you get on it, not really much else to say lol.
grittenhou
Do you feel like it helps performance at all?
2006 GTO 6M
2004 Sierra 2500HD
1978 Trans Am WS6
1974 Blazer K5 4M
1968 GTO 400HO 4M
1965 GTO 462 4M
Ilikemtb999
I did a Btr ls3 stage 2 cam and long tubes at the same time so no idea. Honestly doubt it does much performance wise. It adds sound under the hood when you get on it.
grittenhou
Did you go with full LS3 build? If so, what do you think of results?
2006 GTO 6M
2004 Sierra 2500HD
1978 Trans Am WS6
1974 Blazer K5 4M
1968 GTO 400HO 4M
1965 GTO 462 4M
Ilikemtb999
grittenhou wrote: Sun Jul 19, 2020 1:38 pm Did you go with full LS3 build? If so, what do you think of results?
I’m unsure what that means sir. I’ve got the above cam (with supporting mods, long tubes and the air raid intake. I also have a 3.27 diff though I’ve got a 3.45 I’ve been thinking of installing. I have a 3200 stall laying on my bench I need to put in still.
grittenhou
Curious if you removed the active fuel management hardware and/or went with different heads...
2006 GTO 6M
2004 Sierra 2500HD
1978 Trans Am WS6
1974 Blazer K5 4M
1968 GTO 400HO 4M
1965 GTO 462 4M
Ilikemtb999
grittenhou wrote: Sun Jul 19, 2020 6:35 pm Curious if you removed the active fuel management hardware and/or went with different heads...
Yes the dod has to be removed to run a different camshaft (though I saw a guy was running another factory cam with it)
The heads have nothing to do with dod, it’s the lifters, cam and valley cover only.
grittenhou
Installed Airaid CAI and weatherstrip seems to be short by 3 inches. You have same issue? Wrote to Airaid customer service, but no response.
Airaid CAI.jpg (3.22 MiB) Viewed 7553 times
2006 GTO 6M
2004 Sierra 2500HD
1978 Trans Am WS6
1974 Blazer K5 4M
1968 GTO 400HO 4M
1965 GTO 462 4M
that is normal since its a G8 part , plus the caprice not having a hood liner , and taller hood line
