Update!!!2014 ss steering wheel paddle shifters work.
Nate68c10
Post by Nate68c10 » Mon Oct 12, 2020 4:58 pm
Alright since I haven't found much real info on how to make the ss steering wheels work I figured I start my own topic on my pursuit.
I have a 2014 caprice and I have a 2014 ss wheel. I added a wire from pin 21 bcm plug x4 the green bcm plug and ran it with a switch to pin 8 on the clockspring. I turned tutd on with hp tuners and nothing changed, car still shifted on its own.
So I moved the wire to x3 the blue bcm plug and went for a test drive and it drove normally with the switch off but as soon as you turned it on it downshifted to 1st and stayed there. Turn the switch off and back to normal.
Update, I looked at my upshift button and it wasn't snapped all the way in with the wires still hooked up to pin 11 on the blue bcm connector the tutd works as advertised. It will hold it in gear until you bump the paddles. I'll take pictures once I permanently install my switch and route the wire. But for now heres my video proof of function.
RM96
Re: Update!!!2014 ss steering wheel paddle shifters work.
Post by RM96 » Mon Oct 12, 2020 7:36 pm
Success! :)
Nate68c10
Post by Nate68c10 » Mon Oct 12, 2020 8:02 pm
Mounted the switch and tucked the wiring away.
Nate68c10
Post by Nate68c10 » Mon Oct 12, 2020 8:39 pm
Success! :)
Thanks for all the help btw!
Nate68c10
Post by Nate68c10 » Tue Oct 13, 2020 3:11 am
Also I got a lot of leftover pins if anyone wants to try this I'll mail a few to ya free!
Post by s/c'd cav » Tue Oct 13, 2020 4:13 pm
pm'd you my info , greatly apricated !!
AceVL
Post by AceVL » Tue Oct 13, 2020 4:21 pm
Also I got a lot of leftover pins if anyone wants to try this I'll mail a few to ya free!20201012_135621.jpg
PM’D
South Cackalacky
2014 Caprice PPV
2005 Pontiac GTO
1998 Lexus SC400
Nate68c10
Post by Nate68c10 » Thu Oct 15, 2020 4:37 am
Got 4 pins left if anyone else has a ss wheel they want to make shift great again!
Turbopowered68
Post by Turbopowered68 » Sat Nov 14, 2020 12:02 pm
badass
2014 Caprice V8
Elgin E-1840 P, LS9 Head gasket, LS7 Lifters, PAC-1218 springs, Trunion upgrade, Single roller timing set, Melling oil pump coming soon - ZL1 torque converter, Trans pan and filter.
1986 GN 212/212 Roller cam, 1.65 HR Rockers, 60-1 turbo, XFI 2.05, E85, Ebay Front mount IC, Husek Built TH200-4R trans, 3.42 gears 3800# .
1968 Chevelle LQ4, 4L80, 12 bolt w/3.42 gears
Turbopowered68
Post by Turbopowered68 » Sun Nov 29, 2020 4:32 pm
if still available, i'll take them for my build
2014 Caprice V8
