Page 1 of 2
Update!!!2014 ss steering wheel paddle shifters work.
Posted: Mon Oct 12, 2020 11:58 am
by Nate68c10
Alright since I haven't found much real info on how to make the ss steering wheels work I figured I start my own topic on my pursuit.
I have a 2014 caprice and I have a 2014 ss wheel. I added a wire from pin 21 bcm plug x4 the green bcm plug and ran it with a switch to pin 8 on the clockspring. I turned tutd on with hp tuners and nothing changed, car still shifted on its own.
So I moved the wire to x3 the blue bcm plug and went for a test drive and it drove normally with the switch off but as soon as you turned it on it downshifted to 1st and stayed there. Turn the switch off and back to normal.
Update, I looked at my upshift button and it wasn't snapped all the way in with the wires still hooked up to pin 11 on the blue bcm connector the tutd works as advertised. It will hold it in gear until you bump the paddles. I'll take pictures once I permanently install my switch and route the wire. But for now heres my video proof of function. https://youtu.be/3kZr-RX0CtQ
Re: Update!!!2014 ss steering wheel paddle shifters work.
Posted: Mon Oct 12, 2020 2:36 pm
by RM96
Success! :)
Posted: Mon Oct 12, 2020 3:02 pm
by Nate68c10
Mounted the switch and tucked the wiring away.
Posted: Mon Oct 12, 2020 3:39 pm
by Nate68c10
RM96 wrote: ↑Mon Oct 12, 2020 2:36 pmSuccess! :)
Thanks for all the help btw!
Posted: Mon Oct 12, 2020 10:11 pm
by Nate68c10
Also I got a lot of leftover pins if anyone wants to try this I'll mail a few to ya free!
Posted: Tue Oct 13, 2020 11:13 am
pm'd you my info , greatly apricated !!
Posted: Tue Oct 13, 2020 11:21 am
by AceVL
Nate68c10 wrote: ↑Mon Oct 12, 2020 10:11 pm Also I got a lot of leftover pins if anyone wants to try this I'll mail a few to ya free!20201012_135621.jpg
PM’D
Posted: Wed Oct 14, 2020 11:37 pm
by Nate68c10
Got 4 pins left if anyone else has a ss wheel they want to make shift great again!
Posted: Sat Nov 14, 2020 6:02 am
by Turbopowered68
badass
Posted: Sun Nov 29, 2020 10:32 am
by Turbopowered68
Nate68c10 wrote: ↑Wed Oct 14, 2020 11:37 pm Got 4 pins left if anyone else has a ss wheel they want to make shift great again!
if still available, i'll take them for my build
