Thanks. So it's a truck dipstick you're using. How did it go in? Did you have to mod it at all to fit?Turbopowered68 wrote: ↑Wed Apr 14, 2021 7:48 pmACDelco GM Original Equipment 24260606
15796802 - SEAL - General Motors
24267668 - INDICATOR - General Motors
2014 Caprice not conventional build
Re: 2014 Caprice not conventional build
Trans was out
positioned Dip stick into the body over the motor from the bottom of the car.
as the trans was being lifted into position the dip was being guided into the tran's fill hole.
walla dip stick tube is in.
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
A lot of folks appear to be going with the Camaro LT 18" rims, I just put a set on my car like that. Eagle Sport tires in 245 flavor from a 2016. Low mile take-off.
I had to go to stock size tires as my car was rubbing at all 4 corners.
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
Thanks for letting me know. We checked for clearance at the tire store, although I suppose with suspension movement over stiff bumps and at speed it's possible that rub could be occurring. I'll keep a close eye on it to see if I see it as well. The tires aren't brand new but do have plenty of rubber on them, so it won't hurt as much if I have to go back to 235's.
Working on the tune. This tune is based off of the OE tune and YT videos and a few things from the tune I purchased.
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
I did a ton of research on Burst Knock after everyone kept saying to turn it OFF.
So Burst Knock is now OFF new log coming soon.
I am hoping that with the Burst Knock off the low RPM and low load KR goes away.
ALSO I got the Wideband sensor just need to install it.
I am considering eliminating the front Cats.
When adding the O2, would installing it after a Y be better than just reading one bank?
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
Got these today, hopefully i'll get to install them soon.
- 20211226_013431.jpg (3.2 MiB) Viewed 2860 times
- 20211226_013422.jpg (2.75 MiB) Viewed 2860 times
- 20211226_013417.jpg (4.25 MiB) Viewed 2860 times
- 20211226_013410.jpg (4.91 MiB) Viewed 2860 times
- 20211226_013405.jpg (3.67 MiB) Viewed 2860 times
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
Going to be adding a Wideband sensor.
Where is the best place to install it??
1- Bank 1 Close to the engine
2- Bank 2 close to the engine
3- After the Y= Further away from the engine than option 1 and 2
Exhaust layout will probably be
Both headers into a single 3 inch intermediate pipe
Into another a Y to both OE Mufflers.
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
The advice I got for the wideband location if you are going with a single sensor is bank 1 (cyl 7 tends to run leanest) and as close to the upstream sensor as possible. The fewer gaskets/connections between the head and sensor location the better, less chance of a leak throwing the readings off.
