2013 PPV Weekend Warrior/Mad Max Build
Re: 2013 PPV Weekend Warrior/Mad Max Build
Nice work on the wheels, I had wondered if they tapered in that area. I guess not.
325/45-18 Hoosier DOT Drag Radials on Widened Factory Rims . . . it is a BIG tire
Tire Diameter: 30.20 in. Section Width: 13.10 in. Tread Width: 11.20 in.
- wides.jpg (890.25 KiB) Viewed 7013 times
I wanted an easy to see gear indicator. Works good with tap shift box. Also opened my eyes as to how quick I am out of first gear when I have the short tires on. Plugs right into OBD port.
http://www.speartech.com/6L80gearindica ... icator.htm
Hmm, where did you get that indicator? I have the shifter box, but would be curious what gear I'm in when using it, too. Probably only use it if we were autocrossing or went to the drag strip, though, so a temporary OBD port plug-in would be optimal.
Nice work. Especially impressed with the rims. I want to do that to mine also. Sleeper looking but needing more traction. I have a build thread I'm about to post also. Almost done, complete engine and trans rebuild. Did the rims hold up well enough? I have a lathe and tig and could probably do them, I was just concerned about them holding up to the abuse of heavy foot driving.
Water/Meth + 180hp N20
Holley 120lb injectors
Link for it is just above the picture - kinda hard to seeCrashTestDummy wrote: ↑Sun Aug 15, 2021 3:44 pm Hmm, where did you get that indicator? I have the shifter box, but would be curious what gear I'm in when using it, too. Probably only use it if we were autocrossing or went to the drag strip, though, so a temporary OBD port plug-in would be optimal.
Rims are GREAT. I can't take credit for the welding - a friend of mine hooked me upandrewquant wrote: ↑Mon Aug 16, 2021 10:33 am Nice work. Especially impressed with the rims. I want to do that to mine also. Sleeper looking but needing more traction. I have a build thread I'm about to post also. Almost done, complete engine and trans rebuild. Did the rims hold up well enough? I have a lathe and tig and could probably do them, I was just concerned about them holding up to the abuse of heavy foot driving.
Now that my son is 17, he wants something 'unique'
(He's tired of driving my generic 2020 Crosstrek)
So I was lucky enough to find a V6 at auction for a nice price
2014 with only 64K Pretty excited about a V6 daily driver build
It came with the lights and all? Man, that would be illegal here, especially after what happened here in Nova Scotia https://en.wikipedia.org/wiki/2020_Nova_Scotia_attacks. In fact, the RCMP has stopped selling their old PCs to the public even if they are stripped.
