This is the Window Switch connector information for a WM 9C1 pictured below:
Will break our each connector in it's own post.
Window Switch Connector info
X504 Gray Oval
Gray Oval Connector- X504 Window Patch Harness to the Left Front Door Harness
8 Cavity
Description: 8-Way F 2.8 Series, Sealed
No terminal information in service manual
Yazaki YES/YESC Kaizen Connector series
Part Number : 7283-5574-10
https://connectors-catalog.sys.yzk.co.j ... &select=05
Purchase Info:
Nexus - 40 piece minimum : https://nexelec.com/YAZAKI-7283557410/
Corsa - 1 piece minimum : https://www.corsa-technic.com/item.php? ... urer_id=45
8 Cavity
Purchase Info:
X505 Black Oval Connector
Black Oval Connector- X505 Left Front Door to the Window Patch Harness
16 cavity
Description: 16-Way F 090 II Series
Part Number: 7283-4736-30
Looks to be a good Yazaki part number and description but nothing in thier catalog.
Looks like molex makes a simlar one? in the MX150 series
https://www.molex.com/molex/products/fa ... tor_system
Purchase Info:
Molex : https://www.corsa-technic.com/item.php? ... ory_id=134
16 cavity
Purchase Info:
White Rectangle Connector
7 cavity
No info found in pinout file???
7 cavity
A10 Black Rectangle Connector
Black Rectangle Connector - A10 inside Rear View Mirror
16 cavity
No terminal information in Service manual
12124239 does not appear to be a good 16 cavity part number
Drawing does not look correct either.
16 cavity
