Should there be lights under the gear selector in a 2011?
So I have a 2011 9C3 (with the offset shifter). Should the gear indicator area (PRNDL) be lit up from underneath? The Sport and Traction Control buttons do light up, but not the gear indicator by the shifter. Thanks!
Re: Should there be lights under the gear selector in a 2011?
Yes but it is a LED. Not sure if it even serviceable? Maybe soldered on a board.
https://www.newcaprice.com/forum/viewto ... art#p32192
Oh wait off set shifter? Thats a 9C1 shifter then.. NOt sure about those lighting up??
My 2012 9C1 offset shifter gear indicator is lighted. I would imagine that the 2011's would also be.
Twin 2012 9C1's
1991 GMC Syclone
1986 Buick Grand National
1991 GMC Syclone
The 11-13 9C1’s are all lighted. Just don’t know if they are identical under the covers, since 11 is a little bit of a red headed step child.
David
David
Ok thanks, I'll poke around next time I get a chance, no rush for this as it's purely cosmetic.
OK so I took the shifter area apart today, and indeed there is a bulb there. It's a type 74 bulb (The bulb was labeled with a 74, that's how I knew...)
I don't seem to see them on Autozone.com, so I'll just order from amazon.com, but right now only seeing a 10 pack!
- PXL_20220221_211118048.jpg (1.78 MiB) Viewed 955 times
That looks like a 193 bulb. They're pretty common and inexpensive if you wanted to give it a try without having to wait for shipping.
Great, thank you... Will try that, definitely do not need 10 of them!
Actually pretty sure this is it on autozone.com:
https://www.autozone.com/electrical-and ... /16841_0_0
The 74 bulb is a smaller base than the 193. I would think you should be able to find a 74 at a local parts store.
